What Pressure Plate Bolts Do I Need? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 12-06-2017, 12:28 AM   #1
Car: 1992 Camaro RS
Engine: 383 Ci Small Block
Axle/Gears: 4.10
Hey Everyone,
I am in the middle of a T56 swap into my 92 RS. I have a 383 stroker, and I bought a 94 LT1 T56 car to serve as a donor for the transmission. I have a 2 piece rear main seal motor, so I had to get a new flywheel. I ordered this one from summit: https://www.summitracing.com/parts/sum-700185. However, I am now trying to bolt the LT1 pressure plate to the flywheel, and the bolts (from the 94 Camaro originally) are not long enough to reach the flywheel. I was wondering if anyone knows what bolts I need, or if there is another problem.
Thank you for any input!
Dom Scarpellino is offline   Reply With Quote
Old 12-06-2017, 07:22 AM   #2
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: What Pressure Plate Bolts Do I Need?
you need a LT1/T56 specific flywheel for the two-piece RMS.
naf is offline   Reply With Quote
Old 12-06-2017, 07:59 AM   #3
Car: 1992 Camaro RS
Axle/Gears: 4.10
Do have any idea who makes something like that?
Old 12-06-2017, 08:20 AM   #4
jmd
Car: `86 SS / `87 SS
McLeod has them.
jmd is offline   Reply With Quote
Old 12-06-2017, 08:36 AM   #5
Car: 1992 Camaro RS
Axle/Gears: 4.10
I found these two: https://www.summitracing.com/parts/CTF-700107 and https://www.summitracing.com/parts/mcl-460370 but they are about twice what I have to spend on a flywheel. And they are the wrong tooth count I need a 168, but the price is the big problem there. Are these the only option?
Old 12-06-2017, 11:58 AM   #6
Drew's Avatar
Clearly you failed to research the swap before you started buying parts.
Yeah those are the two conversion flywheels usually called out. You'll probably need to run a 153t starter anyway to fit the LT1 bellhousing.
The alternative is to convert to a standard type clutch with a hydraulic throw out bearing. That'll probably cost just as much as the $500 flywheel.
Drew is offline   Reply With Quote
Old 12-06-2017, 12:06 PM   #7
Car: 1992 Camaro RS
Axle/Gears: 4.10
Thank you for the advice, I will look in to the 153t starter. No reason to be condescending, some of us are still learning! Obviously I thought I ordered the correct flywheel from what I had read about the swap, or I wouldn't have ordered it.
Old 12-06-2017, 01:53 PM   #8
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
I have a 383 t56. I used a bellhousing from Bob Weir that letís me use any starter or flywheel I want. At the time it was all I could find but I like it and bought a few more to do customers cars.
Biledriver is offline   Reply With Quote
Old 12-06-2017, 02:44 PM   #9
Car: 1992 Camaro RS
Axle/Gears: 4.10
Quote:
How would the bellhousing let you run any flywheel? The issue I am running into with the flywheel is that it doesn't work with the pull type clutch on the t56 because the clutch goes in backwards compared to a normal small block set up.
Old 12-06-2017, 04:56 PM   #10
Engine: 383 sbc
I use a standard 11Ē clutch and it comes with a push style throw out bearing like the LS. Uses any clutch, flywheel, or starter.
Old 12-06-2017, 06:12 PM   #11
Drew's Avatar
Quote:
Sorry, wasn't intended that way... What I was trying to communicate is that there are several in-depth T56 swap threads. The flywheel required with 2pc rms engines is mentioned at least a few times. If you missed the flywheel issue, you may have missed other details that can help you avoid the pitfalls.
TL,DR; Search the forum for T56 swap threads, read the long ones. Lots of good info in them.
Go Back   Third Generation F-Body Message Boards >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
Vendor Directory
1982 Camaro '82 || 1983 Camaro '83 || 1984 Camaro '84 || 1985 Camaro '85 || 1986 Camaro '86 || 1987 Camaro '87 || 1988 Camaro '88 || 1989 Camaro '89 || 1990 Camaro '90 || 1991 Camaro '91 || 1992 Camaro '92
All content copyright © 1997 - 2018 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
