Anybody know what size bolt this is
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Thought my transmission mount was bad but turned out one of the bolts is missing. Does anyone know what size bolt this is ?
Re: Anybody know what size bolt this is
Pretty sure that one is "throw away the V6 crossmember, and get one from a later V8 car in the junkyard"-MM.
By the time you get done tracking down a new bolt, and donut bushings, you'll have more in it than just swapping over to the 1pc crossmember.
Received 1,668 Likes
Right: it's not about "early" or "late", or "6-cyl" or "V8". It's just.... that heinous fluid-filled mount. Which needs to be dispensed with, but unfortunately, to do so requires getting a 1-pc crossmember.
The bolt in question is, if memory serves, 8mm x about 50mm, with matching nut & washers. I don't see it on either of the diagrams unfortunately.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Looks like an M10x1.5 to me. I can check when I get home if you send me a PM after 5PM EST. I have a trans with that mount sitting in my driveway. I can send you the whole thing if you want for the cost of shipping. I'll even clean it for you, I like using my parts washer, lol
Doesn't matter. Same thing. That's why I suggested getting a crossmember "from a later V8 car."
#14 on the V6 diagram. I'd post the early V8 diagram but it's split with the diagram on one page and the parts list on another, and it's the same stupid thing.
It belongs in a garbage can!
Sorry, you're right, M10. 15mm hex. Musta got a brain cramp.
paulmoore
02-19-2018 07:31 PM
