Adjusting Valves
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Adjusting Valves
I'm putting on a set of Comp Mags on my GF's 3.1 RS and was wondering if I set them the same way I do my 350 TPI? Run car and back off till they tick , tighten them till it stops, then give a half turn? I dont do it without running the engine. I've tried millions of times and can never get them right.
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: Adjusting Valves
Car: Formula
Engine: 6.0 LSX
Is that the way to do it though? I've adjusted a ton of cars with it running and yet to have an oily mess, unless the motor is revved.
Car: 1986 Firebird
Engine: 2.8 V6
For what it's worth, the GM service manual says to adjust the lifters with the engine off... we don't have solid lifters or anything; you can get all your adjustment with the engine off- and the only adjustment is seating the pushrod mid-way into the lifter... by putting the lifter plunger in the middle, you get the full range of self-adjustability.
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I was told to adjust lifters a good idea is get a piece of rubber hose and put it on the rocker. As you tigthen you can hear it tick through the hose. Once the ticking stops coming from the hose its tight.
I have never done this. But a few well trained mechanics if I do, then try this method, they say it works everytime.
Car: 1986 Firebird
Engine: 2.8 V6
Only thing is; what's tight? Are they talking about a solid lifter? If you tighten up a hydraulic lifter so the plunger bottoms out, then it's not adjustable anymore.
Hotrodboba400
Dec 10, 2019 07:07 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
