nitrous ?'s
Old Nov 14, 2004 | 04:54 PM
dJLegacyo0's Avatar
Car: 1990 Camaro RS
Engine: 3.1 litre
Transmission: 700r4 :(
nitrous ?'s
mean while i'm saving up for the t5. but i'm wondering wut i would have to do to my engine so it can handle a 125hp wet shot of nitrous?
Old Nov 14, 2004 | 05:31 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
A 125 shot on a V6 is a lot. Some forged pistons would help.
Old Nov 15, 2004 | 09:14 AM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
ALOT!!! Including a rebuild with forged components, And if the engine is out you may as well go ahead and P&P everything, Get a nice set of headers (Pacesetter ) Cam that sucker, get some rockers, and pulleys and go run your self some 14s. Good Luck.
Old Nov 15, 2004 | 10:57 AM
promodvette's Avatar
Car: 91 Camaro
Engine: 280ish
Transmission: torqflite 3 speed
rods and pistons
Old Nov 15, 2004 | 12:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I would not go over 100. holley says 65 is safe on stock parts.
Old Nov 15, 2004 | 12:26 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
75 is safe on a 3.1 Remember, we have decent pistons, and forged steel rods - stock.
I'd say you could do a 100 shot on a well tuned, good running 2.8/3.1 - as long as you had plenty of fuel, and retard the timing a couple degrees.
Old Nov 15, 2004 | 08:26 PM
dJLegacyo0's Avatar
Car: 1990 Camaro RS
Engine: 3.1 litre
nitrous ?'s
Not to get off topic but i'm wondering if i got a shift kit for my auto would it still be about as equivalent in the 1/4 mile as a t5? Doward my 3.1 only has 30,000 on it do you think i could just slap a 100 shot on it if i only change the timing and fuel etc.?
Old Nov 15, 2004 | 08:37 PM
Doward's Avatar
Depends - I'd run a compression test on it, install a new timing chain, and do TomP's tuneup first
Nope. You can't make an auto faster than a stick, at a given power level (to a point) - the stick has less drivetrain loss - means more power always goes to the ground, with a stick. Plus the weight savings
Old Nov 15, 2004 | 08:55 PM
dJLegacyo0's Avatar
Car: 1990 Camaro RS
Engine: 3.1 litre
adf
by tune up you mean like new spark plugs, wires, etc.? I know its got great compression, Changed the oil in it like every 1500 miles. Doward your the man.:hail:
Old Nov 15, 2004 | 10:23 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
sticks always faster
Old Nov 16, 2004 | 05:06 PM
Car: 91 Camaro
Engine: 280ish
Not always...gotta know how to drive it!
Old Nov 16, 2004 | 05:58 PM
dJLegacyo0's Avatar
Car: 1990 Camaro RS
Engine: 3.1 litre
v6
i learned how to drive on a stick. current car is a 95 grand am gt 5 speed. i wuz just wondering if i put the shift kit if it would make it ALMOST as fast as a stick.
Old Nov 16, 2004 | 06:24 PM
Doward's Avatar
It'll help, yes. And also add reliability to your tranny - add an external cooler, as well.
Old Nov 16, 2004 | 07:42 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Hum, 75 shot safe, is that wet or dry kit?
And while were discussing juice. Someone explain the difference between them two, and which one is what is needed for our engines.
Old Nov 17, 2004 | 02:45 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Wet is fuel and No2 sprayed simultaneously. I'm currently running a 50 shot wet, car wil handle more, I'm positive. The 3.4 guys have luck runnin a 125 shot...so anythings possible.
Old Nov 17, 2004 | 04:41 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
I am running a 150 wet shot right now. After ARP studs, new head gaskets, a lot of tuning and some new internals, its holding for now.
Old Nov 17, 2004 | 12:01 PM
FbodTrek's Avatar
....Little on the high side...even for a forged bottom end, but it not unheard of. When you gonna get to the track and get some numbers with that?
Old Nov 17, 2004 | 01:37 PM
Engine: 3.4L 207 V6
I have already been to the track this year. It's easier to make money off of a car if people don't know what it runs. I will probably post times next year. I do need another clutch. Besides, if I posted the times, I would get flamed on the other website because no one would believe it. I was told that you would need timeslips, video footage, signed affidavids(sp?), etc.
Old Nov 17, 2004 | 01:54 PM
Doward's Avatar
Jeez, what website was that??
Old Nov 17, 2004 | 02:11 PM
Engine: 3.4L 207 V6
firebirdv6.com
And 3.1s came w/ forged rods stock? Did the 3.4 come with this little feature also?
Old Nov 17, 2004 | 03:35 PM
FbodTrek's Avatar
firebirdv6.com
Dunno, I thought all of the 60* motors did. You can tell ME Jerriko, I won't tell Alot of the guys at Firbird V6.com think the 3.8 is ***'s gift of somthing, I walked one in a stock S14 auto the other day, had a sticker on the back that said " Race me and Lose" LMAO! He had a 5 spd too. I had my bro in law in the car, he weighs about 200lbs, I weigh about 160.
Old Nov 17, 2004 | 04:41 PM
dJLegacyo0's Avatar
Car: 1990 Camaro RS
Engine: 3.1 litre
Gonna be gettin a ZEX kit. What kit should i get. I hear the one on a 5.0l mustang would work for me. really amped about it. Gonna get the purge kit too! Gonna be makin a few v8's shake when the see the vapor shoot out! haah. well just give me wut kit you used and how much $$$ i'll be spendin.
Old Nov 17, 2004 | 05:40 PM
Engine: 3.4L 207 V6
Re: .
The kit I used is for a 350 TPI setup. Just another reason why I made that custom intake.
Old Nov 17, 2004 | 07:16 PM
FbodTrek's Avatar
Not sure about the price of the ZEX kit, but you could piece a good nozzle setup together for about 300-400 bucks. I've read that ZEX actually give less power than advertised, but are extremely easy to install (the noids are packed into a modue with integrated relays and merely have to attach main power and nitrous/fuel lines). Good luck, enjoy the juicy juice (and try not to waste it merging onto the freeway and such).
Old Nov 17, 2004 | 07:43 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
go with something nice and simple so you don't fry your motor or get killed, stick with a 75 wet shot, nice and safe
Old Nov 20, 2004 | 07:14 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
all this talk about nitrous has me wanting to run out and get it but I don't think my 166,000 mile motor will take it too nicely.
Old Nov 24, 2004 | 03:17 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I second that! Aut has a 20% drivetrain loss...what about a stick?
Have not hit mine with nitrous yet. Got to get the tires to stick so I can launch first. Part of the reason is that there are some kinks we are still working out of the engine and I don't want to get ahead of myself and ruin the motor. Better safe then sorry.
Man i wish there was a track closer then an hour and a half away! I wish Atlanta Motor Speedway would wise up and put one in! I would be there all the time. Tweak and run, Tweak and run!
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
