Need Help Asap
Old Mar 12, 2005 | 06:16 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Need Help Asap
i'm in the middle of swapping timing chain covers, and i found that mine bolts to the oil pan, but the other engine i have (from an 88) doesn't, also the water pump i bought for an 88 doesn't match up at all.
anyone have any ideas?
Old Mar 12, 2005 | 06:38 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
why is the tming cover being swapped?
Old Mar 12, 2005 | 06:50 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm guessing you got an older v-belt cover rather then a serpintine belt cover.
Old Mar 12, 2005 | 08:56 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
that could be it, the problem was the old cover had a ole in it, but i guess i gotta patch the hole and reuse it
Old Mar 12, 2005 | 09:57 PM
Engine: 5.7 / 7.4
jb weld my friend
Old Mar 12, 2005 | 10:22 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
wayyyyyy ahead of you.
it looks like someone swapped the oilpan and the front cover for some reason
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
