Engine Troubles
Old May 10, 2005 | 09:06 AM
Grizzly_Addams's Avatar
Car: 1991 Firebird
Engine: 3.1L V6 MPFI
Transmission: 4 Spd Auto + OD 700R4
Engine Troubles
I have a 1991 Firebird 3.1L V6. I've posted on this board about several problems. Yesterday I found something new.
As it turns out, only 2 of the spark plugs in my engine are becoming fouled. They are the two closest to the front of the car on the drivers side.
There has also been a loud knock in the engine since right after I bought it back in November.
I have been told bad injectors can cause knocking. I am nable to tell where the knocking is coming from. Motor honey/oil stabilizer did not help the knocking.
Now, assume I don't know jack squat except the basics, and how to use tools. Someone please tell me what to go about doing to diagnose my problem. Think I should check the injectors? Well, how do I do that? Please be specific.
Old May 10, 2005 | 11:03 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Well put a long screwdriver or stethoscope against the injector body and put your ear up to it and listen for a regular tick...if the tick is all over the place, or not there, but you can hear it on other injectors, then ya got a bad one....
Uhhhhm....you could try disconnecting the injector connection and plugwire to one of the bad cylinders at a time and see if the knocking changes or goes away.
Old May 11, 2005 | 03:09 PM
Car: 1991 Firebird
Injector body?
Old May 11, 2005 | 08:35 PM
Nixon1's Avatar
Originally posted by Grizzly_Addams
Injector body?
Yeah....as in...the body of the injector. Not...the injector electrical connection, or...the fuel rail. Just put it on the injector!
backtothe80s
Sep 5, 2015 12:39 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
