code question
Old May 19, 2005 | 10:44 PM
shrop's Avatar
Car: 92 firebird
Engine: 3.1
Transmission: 5spd
code question
im always seeing people saying that they have a code 34 or 45 or something like that, how do i find out if my car is "throwing codes" also? is there a tuner type thing i need or what? i wanna make sure im not gettin anything like that... thanks
Old May 19, 2005 | 11:10 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
get a haynes manual, but basically the little plug in terminal below your steering wheel, on the far top right you put a paper clip in the second from farthest and very furthest right holes, turn the ignition on, and it'll flash once long and twice short indicating 12 3 times. After those 3 it will spit out any other codes, a long flash means a 10 so 3 long flashes means 30.
it sounds hard but its so easy
Old May 22, 2005 | 09:06 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
Yes very easy. If you don't want to do the paper clip method, there are little plugins that fit in there perfect, I bought one because i hate getting in there and doing it, this way I can just stick it in and turn the ignition to on and it throws them.
Unless your Check engine light is coming on, you have no use for it. Its still nice to have just incase.
Old May 23, 2005 | 05:18 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Autozone had the code checker key shaped device for our cars. You usually have to ask for one!
Its basically jumpering the 2 terminals in the computer and the car will flash the 1-2 code to tell you its working... then flash the codes at you. Pretty good system for us fixer up ourselfers!
Old May 23, 2005 | 10:52 PM
shrop's Avatar
Car: 92 firebird
Engine: 3.1
Transmission: 5spd
thanks guys, ill try it tommorw, ive benn puting off working on it so much latley..
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
