Code 34
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Code 34
I was driving today for work, then my service engine flashes. So, I came to a stop and I checked out the trouble shooting code. It was a 34, something dat deals with the MAF sensor. I was wondering where that sensor is and how do I fix it?
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
Not sure about about the 3.1 although i think it is the same, it is on the intake tubing going towards the throttle body.
Look for the black tubing coming from the Y intake part, then look for the part of the tubing which has a little plug on the side that says MAF on top, that is it.
Try cleaning the connections and inside first with some electrical contact cleaner then plug ti back in and check again after a little bit. If not, find a used one and see. A new one can be upward of $200 so you want to try and find used or fix the current.
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Well, in the balck tubing, i do not see that sensor, but i believe that sensor is by the light of the hood, where i see a green harness?
Car: 86 Camaro
Engine: 2.8L MPFI
It is before the air from outside reaches the engine, I dont have a light in my hood but my guess is no. If you have a Hanyes or Chilton manual it should tell u, if not I might have mine somewhere around here and I will see if I can find it for the 3.1
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
no 3.1's have the MAF
they all have MAP's which you can find in almost the same spot, but closer to the TB on the intake tubing.
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
