3.1 into 2.8
Old Mar 10, 2006 | 12:18 PM
kwyjibo's Avatar
Car: 1987 ford mustang gt
Engine: 5.0
Transmission: tremec t-5
3.1 into 2.8
what whould be required (besides the engine) to be swaped to put a 3.1 engine into a camaro that originaly came with the 2.8, i have the whole car 1992 camaro 3.1, auto setup (my car, which was totaled)
Old Mar 10, 2006 | 02:36 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the engine harness, dash harness (depending on yr car being swapped into, may as well swap over the guage cluster ( if copatable). That should be pretty much it since you have the donor car. If teh car is quite a bit older, swap over the interior for an updated look too.
Old Mar 10, 2006 | 11:25 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
wow you have to change the harnesses??? I thought the 3.1 swap was pretty much plug and play
Old Mar 11, 2006 | 05:57 AM
Engine: 5.7 / 7.4
iirc, the 3.1 has a ka-nock sensor & the digital/linear egr going for it, along w/the MAF delete thing and an actual bygawd MAP sensor.
Old Mar 11, 2006 | 06:31 AM
daves12secV6's Avatar
just swap in the long block, and bolt on the 2.8 sensors, then u dont need to change anything
Old Mar 11, 2006 | 09:01 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Dave's correct - just swap the sensors and the injectors
Old Mar 14, 2006 | 04:02 PM
iroc-z's's Avatar
Car: 88 camaro rs
Transmission: auto
just wondering how much it would cost to get a 3.1 block?
Old Apr 8, 2006 | 10:22 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Just finished doing one, $1539 shipped, add $50 if shipped to residence.
Chevrolet Long Block Engines by PowerPro Automotive Engines, your complete internet automotive engine dealer!
I ended up with about $2500 when a repair shop quoted me $6500+.
I am retired Navy, so I had the advantage of using the facilities of the Auto Hobby Shop at the local Naval Station (Submarine Base Bangor), had the use of a lift bay, transmission jack, engine hoist, all the tools I could use....
Old Apr 9, 2006 | 05:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you missed the days when you could get GM long block from $50-300 on ebay.
some guy had a big GM parts sell out. I missed the $50-75 ones but remember the $200 ones around $300 shipped. should of bought 3.
eBay Motors: Chevrolet 91-94 191 3.1 liter long block (item 8024324975 end time Apr-20-06 12:29:48 PDT)
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
