after market parts for 60* motors
#102
Car: 1989 Firebird
Engine: 3.1L MPFI V6
Transmission: automatic
Re: after market parts for 60* motors
not just intakes, but any of the parts. like the cams and all that other good stuff. guess i should have clarified in that first one. ha.
#103
Car: 86 Fiero GT turbo, seeking right 86-88 F-bod
Engine: 2.8
Transmission: 4spd
You should add the trueleo hi-flo intake for use with the stock FI system. No need to go to a carb to get more CFM and rpm. trueleo.com
#104
lower intake heater tube fitting
not really aftermarket performance but is somethign common to replace
http://shop.oreillyauto.com/ProductD...pe=938&PTSet=A
#105
Car: '87 Camaro Sport
Engine: 3.4L w/headers, Crower & Hypertech
Transmission: 700R4, B&M Shift Kit
Axle/Gears: ?
TCI Rattler Harmonic Balancer for V6 Camaro
Has anyone installed a TCI Rattler on their V6's? I went onto Jegs website, and it came up under the '87 Camaro V6 application. Went onto Summit's website, and of course it isn't listed as being applied for our engines; this isn't uncommon though. The balancer is part# TCI-870022
#106
Car: 1991 Firebird
Engine: 3.1L V6
I added the Hotchkis Strut Tower Brace to my car without modifying anything. You have to slightly push down the A/C lines near the compressor though.
#111
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: aftermarket parts for 60* motors and v6 cars
Am I the only one to niotice summit has changed and now every link to their site just takes you to the home page.. wtf?
#113
body out there that can help me or point me in the right direction with these problems.
#115
Car: 1991 Camaro RS
Engine: In the process of swaping to 3.4
Transmission: Automatic
Hi can you give me the link to webpage that is selling Full rebuild gasket set for 3.1 engine?
it would be also great if you could advise me gasket set of which brand is better.
thanks
thanks
#117
Axle/Gears: ?
Bore the block, use premium rings, upgrade the camshaft, upgrade the fuel injectors. Headers would be nice.
#118
Car: 82' T/A
Engine: LG4
Transmission: THM200c
T5 bellhousing to mount a ford T5 to 60* (FWD) engines, from a site that makes kits to swap 3400's into MG's
http://www.britishcarconversions.com...category_id=28
Alot of info on 60* engines and swapping them into RWD platforms
http://www.britishcarconversions.com/faqs-mainmenu-25
#120
Car: 89 RS
Engine: 2.8
Transmission: 5 speed manual
Axle/Gears: 7.75" 3.70 gear 9 bolt
i am about to be rebuilding my engine in my 2.8 and i am going to go with a different cam than stock, but dont know which would be better this lunati one from summit http://www.summitracing.com/parts/LUN-06312/ or this comp cam set from them http://www.summitracing.com/parts/CCA-K16-232-4/ . any suggestions? i am also going to be putting the pacesetter headers on there and bringing the exhaust straigh back, x-piping it close to the diff and then bringing it into a magnaflow 2 inlet 2 outlet muffler. sound good?
#121
Axle/Gears: ?
That Comp Cam set is the usual "set" price, but also on the expensive side. I purchased the Crower CompuCam stage 1 for mine which has a comparable rpm range, but with a higher lobe separation angle for better fuel economy; 114 degrees instead of the 110 that the CompCam has. 112 degree lobe separation angle is the factory stock spec which with everyone else factory set is suppose to give 28mpg I believe. A good cam better than the comp cam would be the Edelbrock or Melling which have good numbers for your future dual exhaust set-up.
Question for you though: How would you run your dual exhaust from headers designed for use of a Y-Pipe. The drivers side of the headers are not straight downward angled to run straight back down the car from.
Also, I'm not sure how earlier model headers are shaped. Maybe they both evenly run straight back for what your wanting to do. I do know however, that they will not have the EGR connection on them.
#122
Car: 89 RS
Engine: 2.8
i am not fully sure on the way i am giong to set the exhaust up yet, but i am sure i can figure it out. probably going to run the drivers side in a little bit towadrs the driveshaft then about a foot before the diff i will x-pipe it then go over the axle into the muffler. but with the cam situation i am not looking for a ton of performance, just a bit more and still get fair gas milage sinc i dont get that good of gas mileage now
#123
http://pro-fab.freehostia.com/store/index.php
site is not fully setup yet so if u want to order something or have any questions pm me
#124
didnt like the old site so im starting a new one
link is here
http://profab.xp3.biz/
should b up in a few days
link is here
#125
Car: 1991 Pontiac Firebird
Engine: 383 Stroker, 510 BHP Arnd 450 to Wh
Transmission: TH 350, 3000 Stall. built by ACT PC
Axle/Gears: ford 9" Posi, 3.56?
92 Camaro RS green/gold Heritage Edition suprechared with nx
Custom Cold Air Intake (2.8 - 3.1)
Why pay $200 for a professional intake from SLP (which was designed for V8's) when you can easily make your own for about $60? Not only is it cheaper, but this way you will have a better flowing K & N air filter rather than a generic one from SLP. It is easy to make it yourself, and this installation guide will show you exactly what parts you will need, price estimates, and how it is done. This custom cold air intake will get you between 7- 10 horsepower.
__________
Parts needed:
3" PVC Pipes (~ $12 for all 4 pipes)
-90° elbow
-45° elbow
-straight pipe (exactly 9 inches long)
-adapter (one side with thread inside)
K & N Air Filter (3" cone shaped) (~ $50)
-Part # RE-0810
You can find the PVC pipes at your favorite hardware store such as Lowe's or Home Depot. The K & N Filter will have to be a special order from your local auto parts store such as Auto Zone or Pep Boy's. Most parts stores will not have the item in stock since this specific filter is meant for custom applications. It can also be found on the internet from places like Summit Racing, part # KNN-RE-0810.
Here is what your engine will look like after this modification.
First, disconnect your current intake setup. You will need to take off the long plastic piece, but keep the rubber hose that connects to your throttle body. Unclip the air sensor so you can take out the air canister. Next, unscrew the remaining piece of the air sensor from the canister. On the rubber intake hose, slice off the excess rubber on the top which would normally hold a clamp in place.
Next, if you car has a computer, you will want to drill a hole for the air sensor, about 5/8" wide, into the 45° elbow. Make sure it is in the correct place. You may need to file the hole if it does not fit to allow a secure fit for the sensor. If you make the hole too big, you can always wrap electrical tape around the thread of the sensor for a tighter fit.
Now you can assemble part of your intake. Insert the adapter into the 45° elbow. Make sure you forcefully connect them, allowing a tight, secure fit. Take the K & N filter and insert the rubber opening into the threaded side of the adapter. Push the filter all the way in so it will not fall off.
It is now time to cut the straight tube to the correct size. My tube measured exactly 9 inches. I recommend you test it to make sure that is the right size for you. Place the 90° elbow on the end of the rubber intake tube and place the end with the filter in the correct place in the engine compartment. Measure the length for the straight tube.
Once you have the tube cut, you can assemble the entire cold air setup. Then place it in the engine and attach the end to the intake hose. Wrap some electrical tape at the place where the 90° elbow and rubber hose meet for added security. I could feel a very noticeable difference especially at high speeds. Now go for a drive and listen to that intake scream.
Will this work on a 91 3.1 Pontiac FireChicken? How long do the PVC Pipes have to be? And finally do you have and pics of the setup?
#126
Car: 91' Firebird
Engine: 3.1 LH0 V6
Did you even look at the message you just quoted? He lists everything you need and how to put it all together. basically It'll look like your stock intake made out of PXC pipes and a K&N.
Don't expect to see that 7-10 hp though, going from a stock intake with a dirty paper filter you MIGHT see a 3hp gain, but it's really negligible.
#127
ahh i see, he just confused me a bit in there, and yea i def wasn't expecting a 10 hp gain!
#128
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
So what throttle bodies are a direct bolt up? I heard there was a 4.3 or 3.4 I forgot which one, but you'd have to slightly increase the TB opening to get the full effect.
#129
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Same for you?'
If so what was the Hotchkiss Part #?
TXS
Dennis
#130
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
Here's a list of what we have so far. Note that I have omitted certain components not specifically related to the 60deg v6 or that are listed as replacement parts which may be compatible.
Chips-
Jet stage 1 chip> 18908
Jet stage 2 chip> 18908S
Hypertech chip> 129322
Hypertech chip> 128932
Engine components-
GM performance parts alumium block> 10051141
Probe forged pistons (at fiero store)> 52833
Probe forged pistons (at fiero store)> 52835
ARP rod bolts> 133-6002
ARP head studs> 233-4003
ATI harmonic balancer> 917190
Melling high volume oil pump> M95HV
Sealed power high volume oil pump> 224-4148V
Sealed power high volume oil pump> 224-4152V
Edelbrock chrome valvecovers> 4488
Spectre chrome valvecovers> 5268
Headers-
Pacesetter headers> 72C1206
Pacesetter headers> 70-1206
Ignition-
Mallory mechanical distributor> 4569201
Mallory mechanical/vacuum distributor> 2769201
Proform mechanical/vacuum HEI distributor> 67082
MSD cap & rotor kit> 8430
Accel cap & rotor kit> 8133
Mallory rotor> 331
MSD HEI coil> 8226
Proform HEI coil > 66937C
Crane ignition box & coil kit> 6000-6302
Pertronix HEI ignition control module> D2000
Accel HEI ignition control module> 35361
Induction & fuel-
NOS 3.4/3.8 nitrous kit> 05175NOS
(most generic carbs compatible with use of edelbrock 3789 upper intake manifold)
Edelbrock intake manifold (upper 2bbl)> 3787
Edelbrock intake manifold (upper 4bbl)> 3789
Edelbrock intake manifold (lower)> 3785
(most generic injectors compatible)
Underdrive pulleys-
Auto specialties pulley kit> 541801
Jet pulley kit> 90108
Valvetrain-
Edlebrock cam & lifter kit> 3790
Comp cam> 16-233-4
Comp cam> 16-232-4
Comp cam> 16-115-4
Crane cam> 250511
Crane cam> 250801
Crane cam> 251241
Crane cam> 253901
Crane cam> 253941
Crane cam> 254112
Crane cam> 254122
Lunati cam> 06312
Melling cam> MTC-5
(most sm block v8 lifters compatible)
Comp roller tip rockers> 1414-1
Crane alum roller rocker (single)> 25750-1
(most sm block v8 rockers compatible with use of 3/8" or 7/16" studs)
Cloyes roller timing chain> 9-3137
(most sm block v8 and LS1 valve springs compatible with use of associated hardware and/or spring pocket machining)
Links-
www.kb-silvolite.com > large resource for replacement pistons
www.60degreeev6.com/store > ported cylinder heads/ intake manifolds/ throttle bodies, crank scrapers, ect.
www.fierostore.com > ported cylinder heads/ throttle bodies, forged pistons, ect.
www.engine-parts.com > stroker kits, shortblocks, cams
mrzperformance.vstore.ca > ported throttle bodies, underdrive pulleys, billet oil caps
Chips-
Engine components-
Headers-
Ignition-
Mallory rotor> 331
MSD HEI coil> 8226
Induction & fuel-
Underdrive pulleys-
Valvetrain-
Comp cam> 16-233-4
Comp cam> 16-232-4
Comp cam> 16-115-4
Crane cam> 250511
Crane cam> 250801
Crane cam> 251241
Crane cam> 253901
Crane cam> 253941
Crane cam> 254112
Crane cam> 254122
Lunati cam> 06312
Melling cam> MTC-5
Links-
#131
Car: 91 firebird special editition #132
Engine: custom 3.5L v6
Axle/Gears: 3:73
I'm looking for a fresh air package for my 91 firebird v6. I've done quite a bit for the motor. 3.4 crank and cam, .040 cylinders, ported heads, performance ignition system, etc. Now I need to do exhaust and intake upgrades. Preferably a system compatible with k&n air filters. Can anyone help me out?
#132
Car: 91' Firebird
Engine: 3.1 LH0 V6
Take off the canister and bottleneck that the airfilter normally sits in, get some sheet metal and cut it into a barrier that blocks off the filter from the engine bay with some universal weatherstripping on the top to seal against the hood. Then replace your filter with a k&N.
It's more free flowing, and you keep the hotter air of the engine bay away. Since doing this I've tested it, and the air is usualy kept 5-15* cooler than the engine bay air (depending on speed and outside temps).
#133
I agree. Any way you can route the air into the engine from outside the engine bay will work. Get creative and just make what works. Just dont forget to move the IAT sensor and extend the wire for it, if you remove the canister and just route piping or hose to grab the fresh air.
You can also fab some things together if need be with silicon connectors off ebay. There pretty low cost and also look nice depending on what color you choose.
But since your stuck with a K&N filter already modding the canister to the outide fender would work well also.
#134
Axle/Gears: 3:73
That's the same thing I was thinking. Actually, on the 91's with the aero package they have 2 lower air dams. I can use the passenger side one to force air into the box.
#135
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Any California legal headers ? Is a delta cam 260 grind smog legal ? Are there any turbos california legal ?
#139
Car: 1988 IROC-Z28 with a V6
Engine: 3.1L V6 LH0/3100 L82 Hybrid
Transmission: Borg-Warner NWC T-5
Axle/Gears: 2HL/GU6 3.42 open
No headers specifically for the 3.1. 2.8 headers require AIR system delete because the pump to manifold fitting isn't on the #3 primary. Which I believe means no-go in California.
#141
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
any new links for parts since summit shut down, looking at exhaust and some sort of CAI for my 1984 Camaro 2.8l Carb, for exhaust i was thinking a dynomax super turbo muffler and a magnaflow high flow cat, any opinions? an
1992 Trans Am
02-03-2019 05:10 AM
