after market parts for 60* motors
Old 09-06-2006, 11:15 PM
daves12secV6's Avatar
aftermarket parts for 60* motors and v6 cars
im going to compile a whole list of every known aftermarket engine part for the 60* motor.once i get a full listing ill orginize it a lil better
to start off this is everything from summit,if u know of other parts and have links plz post them up and i will add them to the list.
replacement carbs
Holley Remanufactured Carburetors: HLY-64-80081 - summitracing.com
intakes
Edelbrock Performer Intake Manifolds: EDL-3787 - summitracing.com
Edelbrock Performer Intake Manifolds: EDL-3785 - summitracing.com
camshafts
Edelbrock Performer-Plus Cam and Lifter Kits: EDL-3790 - summitracing.com
COMP Cams High Energy Camshafts: CCA-16-233-4 - summitracing.com
COMP Cams High Energy Camshafts: CCA-16-232-4 - summitracing.com
COMP Cams High Energy Camshafts: CCA-16-115-4 - summitracing.com
Crane CompuCam Cam and Lifter Kits: CRN-254122 - summitracing.com
Crane CompuCam Cam and Lifter Kits: CRN-254112 - summitracing.com
Crane PowerMax Camshafts: CRN-253941 - summitracing.com
Crane PowerMax Camshafts: CRN-253901 - summitracing.com
rocker arms
COMP Cams Magnum Steel Roller Tip Rockers: CCA-1414-1 - summitracing.com
pulleys
Auto Specialties Underdrive Crankshaft Pulleys: ASP-541800 - summitracing.com
mufflers
Dynomax Super Turbo Mufflers: WLK-17739 - summitracing.com
cat back systems
Dynomax Super Turbo Exhaust Systems: WLK-17493 - summitracing.com
headers
Pacesetter Headers: PSM-72C1206 - summitracing.com
Pacesetter Headers: PSM-70-1206 - summitracing.com
Clutch kits
Centerforce Dual Friction Clutches: CTF-DF201902 - summitracing.com
Centerforce Dual Friction Clutches: CTF-DF201901 - summitracing.com
computer chips
JET Stage 1 Computer Chips/Modules: JET-18908 - summitracing.com
Hypertech ThermoMaster Computer Chips: HYP-129322 - summitracing.com
Hypertech ThermoMaster Computer Chips: HYP-128932 - summitracing.com
JET Stage 2 Computer Chips/Modules: JET-18908S - summitracing.com
direct replacement cats
Catco Direct Fit Catalytic Converters: CTO-4115 - summitracing.com
ignition stuff
MSD Distributor Cap and Rotor Kits: MSD-8430 - summitracing.com
MSD Blaster GM Coils: MSD-8226 - summitracing.com
Crane HI-6S CD Ignition and Coil Kits: CRN-6000-6302 - summitracing.com
Thermostats
Hypertech Power Stats: HYP-1000 - summitracing.com
Hypertech Power Stats: HYP-1018 - summitracing.com
Summit Thermostats: SUM-360195 - summitracing.com
Summit Thermostats: SUM-360180 - summitracing.com
Summit Thermostats: SUM-360160 - summitracing.com
Suspension stuff
Hotchkis Anti-Sway Bar Kits: HSS-2203 - summitracing.com
Hotchkis Anti-Sway Bar Kits: HSS-2236 - summitracing.com
SLP Performance Parts Heavy-Duty Adjustable Torque Arms: SLE-70803 - summitracing.com
Hotchkis Rear Suspension Packages: HSS-1801 - summitracing.com
Bilstein Sport Series Shocks: BSN-F4VE3C522H0 - summitracing.com
Hotchkis Lower Trailing Arms: HSS-1301 - summitracing.com
Eibach Sportline Lowering Spring Sets: EIB-4-0138 - summitracing.com
Eibach Pro-Kit Lowering Spring Sets: EIB-3801-140 - summitracing.com
Competition Engineering Bolt-On Frame Connectors: CEE-3111 - summitracing.com
Suspension Techniques Sway Bar Sets: STQ-52075 - summitracing.com
Lakewood Traction Action Lift Bar Kits: LAK-21700 - summitracing.com
Edelbrock Adjustable Torque Arms: EDL-5282 - summitracing.com
Hotchkis Weld-On Subframe Connectors: HSS-4001 - summitracing.com
HAL Generation F Series Shocks: HAL-TC2502P - summitracing.com
Hotchkis Adjustable Panhard Rods: HSS-1501R - summitracing.com
Moroso Trick Front Springs: MOR-47210 - summitracing.com
KYB AGX Adjustable Gas Shocks and Struts: KYB-735001 - summitracing.com
Energy Suspension Hyperflex Bushing Kits: ENS-3-18131R - summitracing.com
Energy Suspension Hyperflex Bushing Kits: ENS-3-18131G - summitracing.com
Lakewood Drag Shocks and Struts: LAK-40510 - summitracing.com
Lakewood Drag Shocks and Struts: LAK-40500 - summitracing.com
Lakewood Rear Lower Control Bars: LAK-20140 - summitracing.com
Moog Strut Mounts: MOG-K6414 - summitracing.com
Energy Suspension Motor & Transmission Mount Kits: ENS-3-1130R - summitracing.com
Edelbrock Heavy-Duty Tie Rod Sleeves: EDL-5250 - summitracing.com
Old 09-06-2006, 11:38 PM
that should be enough to get this started
Old 09-07-2006, 01:42 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
Clutches
Drivetrain Components
Engine
Valvetrain Components
Old 09-09-2006, 01:04 PM
can i get an admin to stickey this plz
gonna add more stuff later
Old 09-09-2006, 06:24 PM
Street Lethal's Avatar
I vote for sticky as well. Mods, I have a feeling that this V6 forum will be flooding with members in the months to come. Dave's dedication to V6 F-Body performance is without question, and his research with Turbo's, as well as aftermarket performance, will definitely help out a lot of newbie's....
Old 09-10-2006, 09:35 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
I for one vote to make this a sticky as well,.,.Also im greatfull for (daves12secv6) and others input to this forum., ive learnd so much and continue to learn all the time.,.,.,.,Thanks
Old 09-10-2006, 10:01 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
The water pump isn't a proper listing. The 660s use a very different water pump than V8s and other V6s.
Just skimming through the rest seems to be listed alright.
Old 09-10-2006, 05:31 PM
thnx for the heads up
Old 09-15-2006, 06:31 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
good list. the only thing thats really missing is the pain......there is still the little off brand parts places.....remember the overly expencive intake. then there is that one company that reworks the heads and sells them.
and the one thing you forgot was the mallory dist. at summit
Old 09-16-2006, 08:30 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Suspension Restoration Parts Co. - G.M Truck, polyurethane suspension bushings
this one is for poly engine mounts.
Old 09-16-2006, 01:37 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
sad thing is lots of stuff is built for 82-89 and not for 90-92 3.1Ls..
i want an aftermarket intake fior my 91
Old 09-16-2006, 03:53 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
sticky......................... do it.
Old 09-16-2006, 06:18 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
no aftermarket TPI intakes for a 3.1?
I really want to build this thing up slowly over time, and when I swap the V8 into the car I'll have a stout 3.1 to swap into the Toyota 4x4
Old 09-16-2006, 10:34 PM
drdave88's Avatar
Engine: 6.0L
since youve got a camaro. your intake setup already flows more than youll ever need. and its a factory cold air intake, its in front of the radiator. if you put a cone filter on under the hood, youll be sucking warmer air than you are now. if you had a firebird, that would be a different story. just cut the bottoms of the boxes off yours now and throw some K&Ns in and youre as good as youre gonna get. also, just about anything for a 2.8 will work on a 3.1. theyre almost identical except for the 3.1 has a few more cubes and is speed density (better).
do a search about the air box gutting. doward posted some really good pics a couple of years ago on this, youll notice a bit more pull on top end. but remember, youre already running a v8 intake setup. how much better can you get?
Old 09-16-2006, 11:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Daves12sec, cool list! Closest I ever found to a better water pump was the Meziere's line of electric remote pumps; but yeah, they're pricey, back when I looked it was > $300 for a remote pump that was "streetable" (versus track-only).
Sogabe, actually, most of that stuff works for you too- except an intake. Don't forget us 2.8 MPFI guys don't have an intake either. A carb'd intake is only for 82-84 models. That's part of the fuel-injected 2.8/3.1 "curse"... no intakes.
DrDave88, thanks for the poly mount link! Have you used their products on an f-body? I had heard that the 4.3 V6 poly motor mounts were the same as V8 mounts; will they really work on 2.8 f-bodies?
Old 09-17-2006, 08:18 AM
drdave88's Avatar
Engine: 6.0L
i bought them, i have them sitting in the garage. i had one of the mounts out but i didnt have enough time to drill the clamshell apart and get it in before my shop was gonna close so i had to throw it back together. theyre a nightmare to take out, lol. but yes they will fit. theyre for the 2.8 s10s and similar, which share the same mounts as our cars.
Old 10-04-2006, 07:16 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
bump, hate having to search for this everytime i want to find something
Old 10-04-2006, 10:37 PM
drdave88's Avatar
Engine: 6.0L
im hoping to get something going this winter to get the motormounts out of my car and get the new ones in over the winter. just gotta find a way to get a cherrypicker up to me (1.5 hrs away) w/ only driving a cavalier, lol.
Old 11-16-2006, 03:09 PM
anyone else have more parts to list
Old 11-16-2006, 06:51 PM
http://www.engine-parts.com/GMV6/gm28stroker.html
Old 11-17-2006, 11:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
hypertech makes a coil that fits.
accell makes a coil and ICM that fits.
IIRC, crane makes roller tipped rockers in 1.6 and 1.52
cam, the melling MTC-5
melling has a high volume oil pump.
jet also made pullys, but I had problems getting the proper one sent to me
sorry I dont know the part numbers off the top of my head.
Old 11-22-2006, 08:24 PM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
The melling MTC-5 at summitracing.com:
http://store.summitracing.com/partde...0&autoview=sku
part# MEL-MTC-5
summit seems to be the only place I can find that has it.
Old 12-07-2006, 06:42 PM
monkeycamaro's Avatar
Car: 1991 V6 Camaro RS
Engine: 3.1L V6 (kinda pathetic)
Transmission: 5-Speed Manual
what about V8s
I know that you are more interested in V6 parts but i was wondering if you could make a list of good engines to put in.
Old 12-07-2006, 08:38 PM
drdave88's Avatar
Engine: 6.0L
any of the 60 degree engines are a good upgrade. the 3.4 swap is the best for the money. any other engine swaps (aside from a v8 swap) are not easy to do and arent very well documented. project85 did a 3800 swap but it never really made it completely, so i dont think hell call it sucessful.
Old 12-08-2006, 07:59 PM
I HAVE FOUND A SOURCE FOR THE V6 AUTOMATIC TRANSMISSIONS AND PROPER CONVERTERS
http://www.performabuiltautomatics.com/
they do not list the 660 auto trans specifically or the converters but contact and let them know ur needs,they have transmissions and converters instock
they come highly recomended on another board i am on
Old 12-08-2006, 10:44 PM
automatic sucks
Dont convert to an automatic transmission MANUEL TRANSMISSION ALL THE WAY
where can i find performance V6 engines (drop-in turn key) for my 91 camaro
Last edited by monkeycamaro; 12-08-2006 at 10:46 PM. Reason: Automerged Doublepost
Old 12-08-2006, 10:57 PM
not in drag racing were consitancy is needed,and auto is better,also in a case of a turbocharged engine an automatic car will be faster since u dont lose boost on gear changes
Old 12-08-2006, 11:27 PM
firstfirebird's Avatar
Dave, new sig looks slick! - did you use photoshop?
Not to mention when running turbo, I hear it's best to have auto for the simple fact that you can hold the brake while slightly step on the accelerator to get your RPM's up enough to take off under boost.
Old 12-09-2006, 12:28 AM
for driving
i dont know whats best for drag racing but i no that manuel is more fun to drive with
Old 12-10-2006, 06:37 PM
Car: 1985 Firebird
That really depends on your definition of fun.
Old 01-13-2007, 12:58 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
Originally Posted by daves12secV6
anyone ever head anything good or bad about these guys? I wanna do a new engine for the maro but there is not much out there. Maybe i should just get the HT 3.4 from SDPP for like 1800 bucks.
Old 01-13-2007, 11:49 PM
drdave88's Avatar
Engine: 6.0L
depending on how cheap (and mileage/condition) you can find a 3.4 in a junkyard, just get that and mod that. itll probably be cheaper, as long as you dont have to do any work on the short block or major head work. i got my 3.4 engine w/ all the accys. shipped from florida to michigan for $750. check ebay, theyre always cheap there.
Old 01-15-2007, 11:03 PM
AUTOMATIC STALL CONVERTER
http://www.tciauto.com/Products/Conv...plications.asp
SCROLL down and find
part number 243200
Old 02-02-2007, 05:22 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
MAA-4569201
Mallory performance distributor for 84-87 2.8's on Summit.
Old 02-03-2007, 03:27 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Tubular K member, RCA, PHR, coilover conversion, tubular front control arms...
http://www.americanracecomponents.com/camaro.html
Old 02-03-2007, 08:46 PM
djwimbo's Avatar
Car: 91 camaro T-Tops
Transmission: Borg T5
I'm not by any means a v6 guy, but i want to swap one into a chevette. What's the difference in years of 60 degree v6's? 82-89 or 90-92? plus since the 3400 v6 in an Alero, etc is based off the same 60 degree block, can't i just go backwards in technology and make it stupid and MPI instead of SFI ? otherwise they're all the same size other than intakes right?
Old 02-03-2007, 09:14 PM
Posted in the wrong thread,
This is a sticky for you to list 60* performance parts...
Maybe this link will help you (Click Here)
Old 03-18-2007, 10:07 AM
Also check www.domesticcrew.com
We are more specialized in the J-body, but welcome any platform, and have quite a few members with extensive knowledge of the 660 of all generations.
Old 06-06-2007, 01:58 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: after market parts for 60* motors
V8 rocker arms work fine if the heads are drilled and tapped for 7/16" rocker studs, v8 lifters drop in too which opens up the use of rhoads lifters and solid rollers (but only rollers with a flat base will work, chamfered ones expose the oil hole, which means no oil psi and crying) but you'll need custom pushrods made. www.fierostore.com has Probe forged pistons and moly rings for the 2.8 and NOS makes a nitrous kit for the 3.4. Don't forget GM's (expensive) aluminum racing block, not aftermarket but worth mentioning.
Old 06-06-2007, 02:01 PM
Originally Posted by bl85c
V8 rocker arms work fine if the heads are drilled and tapped for 7/16" rocker studs, v8 lifters drop in too which opens up the use of rhoads lifters and solid rollers (but only rollers with a flat base will work, chamfered ones expose the oil hole, which means no oil psi and crying) but you'll need custom pushrods made. Don't forget GM's (expensive) aluminum racing block, not aftermarket but worth mentioning.
u dont have to drill and tap the heads, comp cams makes a direct bolt in studs that are the right size to use sbc rockers
Old 06-06-2007, 02:20 PM
bl85c's Avatar
Car: '85 maro
Crap. I wish I would've known that before I put alum rockers on my 2.8.
Old 06-29-2007, 08:01 AM
  #42
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
need a cold are kit for 3.1 v6 or 2.8 i have it
92 Camaro RS green/gold Heritage Edition suprechared with nx
Custom Cold Air Intake (2.8 - 3.1)
Why pay $200 for a professional intake from SLP (which was designed for V8's) when you can easily make your own for about $60? Not only is it cheaper, but this way you will have a better flowing K & N air filter rather than a generic one from SLP. It is easy to make it yourself, and this installation guide will show you exactly what parts you will need, price estimates, and how it is done. This custom cold air intake will get you between 7- 10 horsepower.
__________
Parts needed:
3" PVC Pipes (~ $12 for all 4 pipes)
-90° elbow
-45° elbow
-straight pipe (exactly 9 inches long)
-adapter (one side with thread inside)
K & N Air Filter (3" cone shaped) (~ $50)
-Part # RE-0810
You can find the PVC pipes at your favorite hardware store such as Lowe's or Home Depot. The K & N Filter will have to be a special order from your local auto parts store such as Auto Zone or Pep Boy's. Most parts stores will not have the item in stock since this specific filter is meant for custom applications. It can also be found on the internet from places like Summit Racing, part # KNN-RE-0810.
Here is what your engine will look like after this modification.
First, disconnect your current intake setup. You will need to take off the long plastic piece, but keep the rubber hose that connects to your throttle body. Unclip the air sensor so you can take out the air canister. Next, unscrew the remaining piece of the air sensor from the canister. On the rubber intake hose, slice off the excess rubber on the top which would normally hold a clamp in place.
Next, if you car has a computer, you will want to drill a hole for the air sensor, about 5/8" wide, into the 45° elbow. Make sure it is in the correct place. You may need to file the hole if it does not fit to allow a secure fit for the sensor. If you make the hole too big, you can always wrap electrical tape around the thread of the sensor for a tighter fit.
Now you can assemble part of your intake. Insert the adapter into the 45° elbow. Make sure you forcefully connect them, allowing a tight, secure fit. Take the K & N filter and insert the rubber opening into the threaded side of the adapter. Push the filter all the way in so it will not fall off.
It is now time to cut the straight tube to the correct size. My tube measured exactly 9 inches. I recommend you test it to make sure that is the right size for you. Place the 90° elbow on the end of the rubber intake tube and place the end with the filter in the correct place in the engine compartment. Measure the length for the straight tube.
Once you have the tube cut, you can assemble the entire cold air setup. Then place it in the engine and attach the end to the intake hose. Wrap some electrical tape at the place where the 90° elbow and rubber hose meet for added security. I could feel a very noticeable difference especially at high speeds. Now go for a drive and listen to that intake scream.
Old 06-29-2007, 08:21 AM
  #43
I didn't see them for 7/16" conversion, only 10mm to 3/8's.
Old 08-01-2007, 06:43 PM
  #44
Car: 1985 Firebird
Hawks is now selling the pace setter headers for the 2.8-3.4 V6 fbods. (as well as the 3.8 V6) 299 for our engines.
Old 08-01-2007, 07:35 PM
  #45
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Here they are for those who don't want to search
http://www.hawksthirdgenparts.com/in...OD&ProdID=1204
Theses look way different from mine.
Old 08-04-2007, 05:28 AM
  #46
maus's Avatar
Car: 70 Firebird Esprit "Formuloid" 350
Engine: 350P/Edelbrock Performer/Q-Jet
Transmission: TH350
Hello everybody,
Mike in Manila checking in again after many years of absence. I originally thought about replacing the 2.8 in my 3rd gen with one of my spare SBC's but was reluctant to sacrifice handling.
I'll be lurking silently in the background while reading up on all the stuff I've missed. Thanks to all for everything already posted.
Cheers!
Mike
Old 08-05-2007, 10:49 PM
  #47
91convert's Avatar
i have a 60* v6 in my camaro that ive been trying to find a supercharger kit for and i finally found a company that makes them they are fageol superchargers http://www.fageolsuperchargers.com/ they make carbureted and fuel injected kits plus accessories to tweak them to your liking like adding ac brackets and custom pulleys!!
oh by the way can someone tell me how to post a main topic on the message board please. thanks
Old 08-06-2007, 03:43 PM
  #48
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Too bad Faegol is out of business as of a few years ago.
Old 08-06-2007, 07:11 PM
  #49
91convert's Avatar
really? they have a website still.. but maybe its old
Old 08-06-2007, 07:30 PM
  #50
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
There was 1 member trying to sell one not to long ago, though. 91convert I would see if 69charger383 still has his, if you still want to go that direction.
Quick Reply: after market parts for 60* motors
