Forged internals
Old Jan 15, 2007 | 07:05 PM
SageMoonblade's Avatar
Forged internals
I have seen this time and time again...... finding off the shelf forged parts for this engine isnt rocket surgery people. The length of our rods and rod journals of our cranks are that same as the small block chevy rods except they will need to be shaved off the sides abit, local machine shop should have no problem doing it. As for psitons if you ar willing to bore your block out abit the Dodge 3.0 v6 pistons will fit and they have a set already in use in the turbo Mitsubishi 3000gt and Dodge Stealths, to use these pistons you will have to bush the piston end of the rod.... again local machine shops should have no problems with this. With that you will have a full forged lower end.
http://store.summitracing.com/partde...5&autoview=sku
Thats the type and specs of the rods you need.
http://importperformanceparts.net/
Click Mitsubishi on the left side, under that click pistons, then click on Wiseco Performance Pistons will be the top engine.
Yes all of this will work without hitting your valves or water jackets while boring.
Any questions ask away.
Old Jan 15, 2007 | 07:59 PM
daves12secV6's Avatar
ur wrong on the rods,they are not the same as a sbc rod, a small journal sbc (327) rod is close to the v6 rod, they need to clearanced on the sides and the big end,and if i remeber right the lil end is onsize
Old Jan 15, 2007 | 08:07 PM
http://60degreev6.com/showthread.php?t=25003
Look it up
Old Jan 15, 2007 | 08:12 PM
i have forged h-beam rods in my motor, i had to machine the big ends,
Old Jan 15, 2007 | 08:17 PM
your right its in the original post 3rd line down.
Old Jan 16, 2007 | 10:30 AM
firstfirebird's Avatar
Wouldn't it be easier to have the piston machined to accept the GM wrist pins?
Old Jan 16, 2007 | 03:58 PM
From what I can see it may be possible up to the user I guess.
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
mfp189
Sep 27, 2015 09:25 AM
roysatikas
Sep 22, 2015 08:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
