3.1 where does the HP come from?
Old Apr 14, 2008 | 12:09 AM
UDAMON's Avatar
Car: Mazda Protege5
so my (1991) 3.1 camaro makes 140 hp correct?
i also have a (2001) 3.1 sebring that makes 200 hp.
seeing that even the newer 3.4s make 160 hp, is there something specific between the two that makes 60 more hp and gets better mpg??
Old Apr 14, 2008 | 03:05 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 3.1 where does the HP come from?
its all down to basics, air+fuel=horses our engines are strangled on the whole intake so no air gets in there which means you cant add lots of fuel cause it wont burn !
our engines are actually good for 200hp on iron heads ( its a common figure that pops up) it just needs releasing.
obviously the sebring has nice flowing intake from the factory, i think that if gm made it right from the factory they wouldnt have been able to sell as many v8 cars which arnt that powerfull due to emisions and stuff, so they had to make the v6 relativly slower - its all about marketting in the end aint it????? thats why they make cars, to make money.
theres also a 10 year difference in technology between the cars on the injection systems and sensors and stuff.
Old Apr 14, 2008 | 11:35 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
The 3.4 is larger (duh), has higher c/r and uses sequential injection. Even though the heads suck and the intake is a joke it's easy to pull another 25hp (not 60) out of a larger engine.
Old Apr 15, 2008 | 10:33 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
your sebring actually has either a 2.7L or a 3.0L
Old Apr 15, 2008 | 10:40 AM
UDAMON's Avatar
Car: Mazda Protege5
doh! my bad... i ment it has the 3.0. lol thanks!
so the potential on these motors is there eh?
thanks for the info guys
Old Apr 15, 2008 | 11:25 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
well, lets first compare a GM motor to GM motor, and even same block to same block.
the RWD 3.1 makes 140hp.
The FWD 3.1 makes 160hp.
Where does the extra 20 come from? Better heads, roller cam(and different profile), and different intake. It also uses the hp better by less drivetrain loss in a fwd setup.
Now if you start comparing other motors. Why is it the new civics with a 2.0 get 225hp while our 3.1 gets 140.
Old Apr 15, 2008 | 11:47 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
this could go on forever, oh dinners up ;-) cya
Old Apr 19, 2008 | 05:30 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Because they have variable valve timing and lift along with OHC setups...oh yeah, they rev to like 7500rpm too.
RPM makes HP in most cases. Look at where the civic makes it's power. Look at the max torque and hp and where they are in the RPM range.
It's all about technology. We have come a long way since 1990.
Old Apr 19, 2008 | 09:39 PM
Dale's Avatar
Engine: 350 S-TPI
You dont have to tell me. I'm just pointing some stuff out.
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
