v6 valves adjustable?
Old Dec 23, 2009 | 12:29 PM
Jack's89GTA's Avatar
Car: 84 SC; 89 GTA T-Top; 2 87 SC T-Tops
Engine: LC1 V6; L98 V8; LC1 V6; 305
Transmission: 700 R 4; 700 R 4; 700 R 4; 700 R 4
Axle/Gears: 3.23; 4.11; 3.23; 3.27
Are the valves in the 84 camaros adjustable? I have a V6 and I don't believe they are, but does anyone know for a fact whether I am right or wrong? Thanks.
Old Jan 19, 2010 | 09:15 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: v6 valves adjustable?
Do you mean VVT? (variable valve timing) if that's what you're referring to, then no they are not.
Old Jan 20, 2010 | 11:09 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I think he's wondering if the lifters are mechanical or hydraulic. In which case, the answer is that they're hydraulic and don't have to be adjusted for valve lash all of the time. If they're making noise, then I would check my oiling system for a fault or the valves for needing some work.
Old Jan 20, 2010 | 12:30 PM
Engine: 3.8, 3.4
Ah, could also mean they're just gunked up some, in which case seafoam should do the trick. Anyways, hopefully one of these things answers his question.
Old Jan 20, 2010 | 01:33 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Every now and again mine will make some weird like burping sound but i dont know what its from. I put a can of restore in it and thats when it started, then i seafoamed it and it stopped, now its back again, so im not sure..... and even when it does it its just at certain speeds and when its cold on first start, idling down....
Old Jan 20, 2010 | 02:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, they are adjustable. They are stud mounted rockers with an adjustment nut. Be careful as some shop manuals say to torque the nuts to a spec. This is incorrect. They need to be adjusted about 1/2 turn down from zero lash.
RBob.
Old Jan 20, 2010 | 07:15 PM
firstfirebird's Avatar
RBob.
Correct.
Book says 1.5 turns, don't go by that far as they will be too tight. The iron head v6 can't have the valve covers off to do the old school method of adjustment while the engine is running since the intake manifolds have to be off for the valve cover removal. I have found 3/4 turn to be perfect, but 1/2 to 1 turn will be fine after zero lash.
If you torque them down, you will have bend pushrods haha.
The late model aluminum heads are torque down since they are pedistal rocker arms, not floating pivots.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
