Code 55
Old Jan 24, 2011 | 07:30 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Code 55
My SOS light came on and my car is stalling at mid rpm, basically if u give it any gas it will drop to 1k rpm then pick back up. When I was driving back from work the SOS light didn't come on and it was fine. I'm going to look for shorts but could it be a bad ecm?
89 camaro 2.8
Old Jan 24, 2011 | 09:13 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Code 55
55 can also be a prob with the egr. Is yours vac or digital?
Old Jan 25, 2011 | 08:15 AM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: Code 55
My egr is vacuum, I don't have it hooked up. It's been that way for year now no problem. How can i check to see if its my egr or ecm. I drove to work and back and no SOS light.
Old Jan 25, 2011 | 05:33 PM
bl85c's Avatar
Car: '85 maro
Re: Code 55
It's not your egr then. Check your grounds & tps.
Old Feb 10, 2011 | 08:19 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: Code 55
My tps was set to 6.6 moved it back to 5.4. Check engine light will come on, I turn car off then back on and no check engine light, seems like it only happens when the car is cold.
Old Feb 10, 2011 | 09:00 PM
bl85c's Avatar
Car: '85 maro
Re: Code 55
What is the tps doing? Backprobe it with a multimeter and watch what the voltage does as you open it. Smooth signal? Drop anywhere? 55 is an ecm related issue although it's not terribly specific. Tap the case with a screwdriver while it's running and see if it stalls.
Old Feb 10, 2011 | 09:15 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: Code 55
The tps got a smooth signal, it seems fine. I'll check the ECM tomorrow, I just took the IAC out and cleaned the tip. When I start the car up it smelt like strong gas fumes.
Old Feb 11, 2011 | 01:24 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: Code 55
Everything seems, good now...no codes but the old one code 33. I just replaced the MAF senor about 6 months ago. Do I need to check the voltage at the MAF?
Old Feb 11, 2011 | 04:03 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: Code 55
Well, I took the intake off to check the resistance on the injectors. I got .01 on all of the injectors? no good?
Sorry just found out my multimeter can't read less then .01 so...i may go buy a new one
Old Feb 12, 2011 | 02:52 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: Code 55
My car is running great untill I was driving to the park and I got a code 36 and 66. I'm going to buy new mass air flow relays...when driving back home...I went over a speed bump and my car died but started right back up.
Old Feb 13, 2011 | 04:28 PM
bl85c's Avatar
Car: '85 maro
Re: Code 55
The number of seemingly random codes you're getting leads me to believe it's a problem with the ecm or a bad ground.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
