HP Guess
HP Guess
If a 3.4 from GM performance is rated at 160 HP with the stock 2bbl carb, then would it have asignificant increase if I have my MPFI on it?
Teach your children the dangers of Rice......88 RS 3.4L 2000 BMW silver. Black and grey interior.
Car: 1986 Firebird
Engine: 2.8 V6
As a personal rule, I don't guess HP, but..
In 1984, the 2bbl carb'd 2.8l V6 put out 90 HP.
In 1985, the "new" MPFI 2.8l V6 put out 135 HP. In fact, the MPFI 2.8 was called a "HO" motor in 1985. The HighOutput designation was dropped in '86.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
haha Tom, i have the HO version then, and that's with 165lbs/ft. of T.Q. not the 160 version.
big wapping 5lbs huh. Well, The 2.8L gained a lot from a FI setup, but my question is whered you get a 3.4L with a 2 bbl. i thought they'd be FI too, now the 3.4L in maros and birds for the early 4th gen, were producing about 160-170hp, so i'm not really sure what u'd get, actually, don't know how you're getting 160 hp from a 2bbl right now. Are there any mods to the motor from the factory? Just curious, not trying to disprove you or anythign.
big wapping 5lbs huh. Well, The 2.8L gained a lot from a FI setup, but my question is whered you get a 3.4L with a 2 bbl. i thought they'd be FI too, now the 3.4L in maros and birds for the early 4th gen, were producing about 160-170hp, so i'm not really sure what u'd get, actually, don't know how you're getting 160 hp from a 2bbl right now. Are there any mods to the motor from the factory? Just curious, not trying to disprove you or anythign. Supreme Member
Engine: 2.8L, LS1
that sounds like a pretty good rough estimate oh HP. good luck with everything.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I've thought about this topic too, as I had been originally thinking of converting to 3.4. Indeed, with a 2bbl it is rated for 160. But REMEMBER, the 3.4 SFI V6 in the 4th gens, to which the GMPP V6 is closely related to, also makes 160hp!! So keep in mind, there should be an increase with the MPFI setup over the carb, but it might not be as great as you hope.
Tom, not so sure where you got the pre-'85 HP #'s from....my sources show 102hp in '82, with 110hp in '83 and '84. Even the 2.5 TBI made 90-95 HP in those years.
Jason E
'89 Camaro RS 2.8 (Medium Gray Metallic)
Hypertech chip/K&N filters/Accel 8.8 wires, Accel Supercoil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm, Keyless Entry
IROC tailights, tinted windows
JasonEE98 on AOL IM
Jason E
JasonEE98 on AOL IM
Where did you find that out?? According to the GMPP catalog, you taka da things offa da 2.8, and you'a slapa dem on the 3.4.
Car: 1986 Firebird
Engine: 2.8 V6
Oops, you're right Jason, I gave the HP spec for the I-4 2.5l, not the carb'd 2.8.
See why I don't guess HP? (laughs)
Oh well, at least my general idea was there- that between "stock" intakes, the 2.8's MPFI will make more power than the 2.8's 2bbl carb'd intake.
See why I don't guess HP? (laughs)Oh well, at least my general idea was there- that between "stock" intakes, the 2.8's MPFI will make more power than the 2.8's 2bbl carb'd intake.
