Underdrive pully ?
Old Mar 4, 2001 | 09:11 PM
Sincat_23's Avatar
Underdrive pully ?
Im thanking of getting the Jet Performance underdrive pully set(3 pullys). My question is were to buy a belt, because I took out my Air conditioning(did not work).Any sugestions would greatly apprieciated.
92 Camaro 3.1 V6 (Red)
-Hypertech Chip
-Dynomax Exhaust
-Taylor Spiral Spark Plug Wires
-2.5 Harwood Lift-Off Cowl Hood
-B&M Megashifter
-B&M Shift Improver
-15x8 Crager 5-Star Chrome Rims
-JSP Apache Wing
-Yellow Weapons-R Intake Filter
-Custom Cold Air Intake
-KYB Shocks & Struts
-Borla Exhaust Tips
-MSD Coil
-Air Lift 1000 Load Assist Springs
-EnergySuspension Swaybar Bushings and Links
Old Mar 4, 2001 | 09:20 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Go to a mechanic or a part store they can help match it up
Old Mar 4, 2001 | 09:47 PM
RenoLB8's Avatar
They're a real easy setup, so just drive it to an Autozone, and swap them in the parking lot, then just keep trying belts til one fits. Most part stores are pretty laid back as long as you hit them when they're not busy.
-Reno
'88 Firebird LB8
"Cerberus"
"You think you're weak and maybe I'm the cure, but I've got 6 pistons in my engine, and I got one for ya...it's a long shot"
http://www.angelfire.com/il/Firebird28/index.html
Old Mar 4, 2001 | 09:55 PM
Kyle F's Avatar
I worked at a prts stroe a few years ago and here is what to do
Get a piece of string about the thickness of a belt
Run it around your routing and tie it of so that it would fit your pulleys. Take it to the store and they will have a belt sizer. This will be much more convienient for everyone involved.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
bryaniskoo
Oct 1, 2015 03:18 PM
italiano67
Sep 22, 2015 08:42 AM
Navy8125
Aug 22, 2015 07:13 PM
