Fast cheap mod.
Old Jun 28, 2001 | 12:58 AM
Monkie's Avatar
Fast cheap mod.
I have been going up and down trying to think about what would be a good cheap mod to do to the V6. Most of you know the mods I got but if you don't here they are...RAM AIR intake, flowmaster muffler, no cat, T5, 8.5mm wires. Ok so now I need a good cheap mod that I can FEEL. I'm not talking about a chip. And really I don't want gears and anyways don't they just take the power you have and spread it around some? Not really giving it a better edge. I was thinking about what Graeme did and get some rockers but Graeme didn't you say that they don't make them anymore? What should I do guys?
And on a side note, this guy with a 94 Eclipse GSX is talking crap. How fast are they?
Old Jun 28, 2001 | 01:11 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hey monkie, where did you find the rockers??
Old Jun 28, 2001 | 01:32 AM
Monkie's Avatar
New Jegs 1-800-345-4545 part number is 249-1413-12
Anyone got any ideas other than these for me?
Old Jun 28, 2001 | 01:42 AM
thanx monkie,
what about some porting or putting an MSD on???
Old Jun 28, 2001 | 08:16 AM
Brian K's Avatar
Get a grinder bit, take your heads off and gasket match the ports.. Cost to you might be 30 bucks with bits and gaskets and you should feel the power.... Also spend a few more bucks and get them hot tanked so they are real clean. If you want to get real wild toss on new valve springs and new rockers and lifters...
Old Jun 28, 2001 | 11:15 AM
AntiVTEC's Avatar
94 Eclipse GSX: 15.2@92MPH with a competent driver and stick shift.
Old Jun 28, 2001 | 12:39 PM
Kyle F's Avatar
I thought you only had a Z-28 Exhaust. When did you put flows on you V6. I didn't know you had already gotten it back. What happen to the 4th genner?
Personally I think you should hold out spending any more money and just save for the Turbo 6 thingy that you wanted to do.
Gears dont add more power true, but they Multiply the power and give your engine a mechanical advantage to move the weight of you car easier. It will show up more than most any other mod other than Forced induction of some sort.
Anyways if you go with rockers make sure they are full roller and increase lift ration. Ineffect you are installing a slightly larger cam and decreasing resistance in your valve train. You will notice this more at High RPMS though.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 28, 2001 | 01:28 PM
Monkie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by AntiVTEC:
94 Eclipse GSX: 15.2@92MPH with a competent driver and stick shift.</font>
THATS IT!?!?! And he is talking crap about beating my Z!?!?! WTF? Time to bet some money....
Old Jun 28, 2001 | 04:07 PM
Tas's Avatar
Tas
GSXs can get 11s easy. watch out. AWD will smoke you off the line if the guy drives ***** out.
GSX= AWD turbo
GST= FWD turbo
GS= FWD non turbo
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jun 28, 2001 | 04:27 PM
Monkie's Avatar
Tas, please explain how a 200hp AWD car can break the 11s. I hope you are talking about modded ones. If so this guys only mod is K&N filter. And he did something that is like free that gave him 2 or so PSI (Woooo!)
Anyways do you think I got him?
Old Jun 28, 2001 | 04:29 PM
Tas's Avatar
Tas
turbo baby turbo. Those are easy to turn up the boost on. Mods come veeeery easy just like Grand Nationals.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Old Jun 28, 2001 | 05:45 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
They no longer make just the roller tip, only full rollers. BTW..if u are wondering the power of adding them, i took out a 95 gt 5 speed yesterday.
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
Old Jun 28, 2001 | 05:46 PM
One more thing..if your not going to take the 14 hours or so to install them, they'll charge u 500 or so to install them...setting valve lash is a bitch.. ALso..GSX's are a LOOOOOT faster than u may think...
1989 Firebird
Coming for my v6:
[This message has been edited by Graeme'sFirebird (edited June 28, 2001).]
Old Jun 28, 2001 | 06:36 PM
Monkie's Avatar
I've seen this guy in action. He was behind me once while I was in the blue 3.1 and he got next to me and flew past me. Wooooo, way to be a sport. I just can never seem to find him when I'm in the Z. And you guys I raced him from a dead stop in the 3.1 and I jumped AHEAD because I can run my V6 with the T5 better than most anything I get in (but don't get me wrong, he raped me about .5 seconds after I jumped ahead). I try that **** with the 5.7 and I'm all over the place. Its a little more trouble to keep them planted. But IF I can get him off the line I have him (hell I think if I don't get him off the line I will chase him down).
Old Jun 29, 2001 | 12:34 AM
AntiVTEC's Avatar
Just hope that GSX is fairly stock. Matter of fact, I've just seen one last night, all riced out and crap. Sounded like a lawn mower on steroids but it was definatly fast. I got a chance to get ahead to peek at the front. Dood had a huge intercooler and I could tell he upped the turbo cuz of the major lag and then the sudden burst. Prolly would have done low 14's cuz he was out fast.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"I'm out to seek those pesky VTEC boys!" (don't get me wrong, I'm asian myself! hehe)
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro.
Old Jul 5, 2001 | 08:57 PM
red90rs's Avatar
turbo on it actually goes up alot more than 2 psi or so as Monkie said earlier. jThey come 10 psi stock and can easily go up to 18 psi on a stock turbo with a larger intercooler(15 on a stock intercooler). I'm in love with turbos, my bros got a 88 t-bird turbo coupe that has a 2.3 4cyl in itt with his boost at 18 and a larger intercooler, her runs 15 flat ina 3450 lb tbird, so if this eclipse which is 3000lbs has his boost turned up... watch your *** , even in a z you'll have to drive to you'll full ability, dont give him any slack. Good luck if you race win won for us!!
Derek Johsnon
90 red rs 3.1 Mods--hypertech thermomaster chip, 160 degree thermostat, and K&N filter
Old Jul 5, 2001 | 09:42 PM
Monkie's Avatar
Oh we raced....I won (didn't see that one coming).... It was such a race, let me tell u.
Old Jul 7, 2001 | 06:48 AM
305camaro85's Avatar
yeah gsx's haul *****. i am glad you beat him that one was mostly stock so no biggie. my sis's boyfriend has a 98 gsx with 440 hp and it hauls major *** . i love that car cuz of it's take off and cuz it beats z06's and vipers. and yes he has raced both . he beat a red z06 that i am friends with the driver and then there is a guy that has 3 vipers here cuz he races them and he got his *** spanked badly. my sis's boyfriend also has a 720 rwhp supra and u definetly need to watch out for this one. he made his own turbo kit for it and it has just about no lag. it is very quick and can spin the tires through all six gears and no brakes. just ramblin on here but imports are fast but i love v-8's and v-6 cuz i have both but beware of imports just not honda's.
85camaro305
mods:3in. exhaust pipe straight from the headers to a glasspack, edelbrock performer rpm intake manifold, edelbrock performer 600cfm elec. choke carb, dynomax headers, no ac and edelbrock signature chrome valve covers and a edelbrock pro flo air cleaner. oh yeah and lots of chrome stuff.
future mods:msd 6al, hei upgrade, and my wolverine cam to be installed, and march underdrive pulleys and a bumpin stereo.
"have u driven over a ford lately"
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
Damon
Sep 26, 2015 04:29 PM
