2.8l Rev out
Old Jul 26, 2011 | 10:53 AM
88iroc86z's Avatar
Car: 86 Camaro Coupe
Engine: currently building a 355
Transmission: unsure what it will end up with
Axle/Gears: 10 Bolt 2.73
2.8l Rev out
I have an 86 Camaro with a 2.8l v6, it starts up with no problems and runs great except for one problem.....
While driving I cannot give it too much gas or the throttle suckes wide open and revs the car out. I then must turn the ignition off and get out of the car and "unstick" the throttle by hand. I have sprayed cleaner inside the throttle body and attempted to clean it however it still has the same symptoms.
Has anyone had this happen to them before and if so can you give me any advice?
Old Jul 26, 2011 | 11:23 AM
Ray the Rat's Avatar
Car: 2010 2RSSS
Engine: 6.2l
Transmission: 6-speed manual
Axle/Gears: 3.45
Re: 2.8l Rev out
I had this happen a short while ago and it was because the clamp at the input of the throttle body was at the wrong angle and the hex screw was interfering with the throttle linkage. I loosened it, rotated it as far as it would go (there's a slot in it that limits travel), tightened it up and the problem was gone.
RtR
http://www.chevyasylum.com
Old Jul 26, 2011 | 11:28 AM
88iroc86z's Avatar
Re: 2.8l Rev out
Thanks I will try this as soon as I get home.
gta892000
Aug 11, 2019 11:16 AM
RedLeader289
May 28, 2019 01:47 PM
bplessy
Sep 30, 2015 12:14 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
