CORRECTION---My fan doesnt cut on until about 230...is that normal
Old Aug 17, 2001 | 10:56 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I have a 89' RS and my fan doesnt cut on until about 230 degrees....its summer time ad it hot here in TENNESSEE but is that still normal...i just put a new water pump on it and i have flushed the radiator good....any suggestions
Old Aug 17, 2001 | 11:24 AM
Camaro_hunter_d's Avatar
normal? sadly enough yes. I swithed the fan swith for another one for an audi (Ithink) maybe volvo. But anyway I went to Napa and looked through there books and found a thermo switch to activate at 175 and to rig it is like any other switch. Power lead from the battery(with fuse) plug to one end of the switch, the other plug to the power wire of the fan. You just have to put in a "t" at the coolant sensor plug.
Old Aug 17, 2001 | 07:48 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Yup, fan kicks in at 227-228 degrees. I verified mine with a digital cooking thermometer. I checked it because my gauge said i was overheating but i wasn't....turned out the Coolant Temperature Sensor was bad. Replaced it and solved the gauge problems.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
