steering wheel shakes
ok well my steering wheel shakes really bad after i start slowing down. i heard it might be my driveshaft. if it is, is this expensive to fix? and is it bad to drive like this?
also, i just rebuilt my engine and there is a bad rattling every once in a while coming from the engine. any ideas what it could be? thanks in advance.
88 Camaro
Rebuilt 2.8
T-TOPS
Flowmaster 80 series
Custom stereo system
88 Camaro
Rebuilt 2.8
T-TOPS
Car: 1983 Pontiac Firebird
Engine: 400HP 350
check motor mounts might have a broken one or it loose
alinement
worped brake rotors
worn brake pads
loose or broken suspendion parts
warn struts or broken ones
check wheel spindles
check bearings in side your brake rotors if they are broken or not greased right they will bind.
Robert
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
alinement
worped brake rotors
worn brake pads
Robert
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
Engine: 400HP 350
check your steering box that may be the prob.
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
Have you tried your breaks? I returned my rotor's and my stearing wheel stopped, is it when you start to break? I might not know all the details, but it could be your break rotor, or the stearing box, good luck
it costs about 50 a rotor from what I hear, have them checked, I'm almost certain thats your problem, I had the same thing with mine, its not the driveshaft
[This message has been edited by GreenMachine92rs (edited August 24, 2001).]
also dont forget to look at your tires for cupping,flat spots,etc. Try rotating the tires to see if that helps. If you find a bad tire, put it on the rear because you wont feel it as much as you would on the front. Maybe get them balanced.
If ya returned your rotors what ya using to stop with (LOL J/K!)
But, the rotors may be warped It could be the drum brakes, BUT
Here's the test.
Drive to an open road, long straight or industrial parking lots, etc.
Somewhere no on else around.
Get up to about 40-ish hit the brakes, hands close by wheel. Watch the action of the wheel.
SHIMMY or SHAKE VIOLENTLY?
Shimmy did ya just change brake pads? AND not turn rotors?
OR did ya do that (have rotors off, turned), or perhaps not attend to proper bearing reseating or greasing or tightening?
Those are clues, let us know.
GENERALLY tires will shake wheel from 40-70 mph, if outta balance.
WHAT HAPPENED RECENTLY TO HAVE THIS EFFECT?
Driveshaft, no. It'd happen all the time (the shimmy).
You'd feel that in your butt.
Wheel, hands front end.
Butt, back end whelles, shaking in the car.
Vibration, loose shield on the AC compressor. Bend it tighter. That happened to mine. Bent it against the unit and the noise stopped.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Here's the test.
Chat Soon,
KED85
Karl
thanks guys, i just got 4 new pirelli tires today and had my wheels balanced and aligned. it hasnt done it yet, but we'll see. if it does it again then i'll check the rotors. thanks for the help.
Chris
Chris
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
