Sputtering engine problem
Old May 9, 2014 | 09:35 PM
Goodreau's Avatar
Car: 1985 Camaro SC
Engine: 2.8L V6
My 1985 Camaro Sport Coupe 2.8L V6 MPFI car drives pretty smoothly with only 52k miles on it aside from my recent sputtering of the engine problem. It muffles and sputters then the little fuel light on my dash panel comes on and the car stalls. I have to put the car in park, turn the car off, back on, then put it in drive and quickly continue down the road. It really only seems to do it when I apply my brakes really hard on an incline, although it's done it in leveled parking lots as well. It's been happening more frequently which has me wondering what this could be? At first I figured it was a fuel filter that was shot so I got that replaced to no avail. The problem still persists. Any help is appreciated. Thanks fellas!
Old May 9, 2014 | 09:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Sputtering engine problem
vacuum leak
Old May 9, 2014 | 10:12 PM
Goodreau's Avatar
Car: 1985 Camaro SC
Engine: 2.8L V6
Originally Posted by Gumby
vacuum leak
I've got some guys on facebook telling me it's fuel injectors going haywire. Could you be a little more specific with the vacuum leak? I'm definitely not competent when it comes to cars. Thanks guys.
Old May 9, 2014 | 10:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
if a car dies when you hit the brakes, its always a vacuum leak. the power brakes will suck the life out of a engine.
Old May 10, 2014 | 12:13 AM
Goodreau's Avatar
Car: 1985 Camaro SC
Engine: 2.8L V6
I'd have to say it's the breaks religiously, in all honesty. It's happened a few times before when just idling so I can't say how credible the breaks theory is.
That's my statement about the breaks ofc, I'm not putting you on the spot or anything.
Old May 10, 2014 | 12:20 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
no clue its your car. anyitme someone says hit brakes and stalls, usually a vacuum problem.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
