turn signals
Old Dec 21, 2001 | 05:26 AM
madreman's Avatar
turn signals
need help... no turn signals at all. i checked all bulbs and they are fine.the switch is fine. the fuse is fine. hazzard lights work but no turn indicators..... at all.
any advise????????????????
Old Dec 21, 2001 | 08:19 AM
WaynesRS's Avatar
I could be totally wrong about this man . Think it could be the wiring ? ...By the way , the man you wanna talk to about the "3.4 swap boogie" is KED85 . I think I just told you Karl .
Wayne
Old Dec 21, 2001 | 09:17 AM
KED85's Avatar
Knowing how to do the 2.8->3.4 swap boogie, you must get lucky and find it in the old threads.
Search for the "2.8->3.4 swap boogie".
Switch. Disconnect the switch harness from the steering column. It down there, under covers and such.
Then figure out which wires in the harness are power & the turn signal part. Then jump wires, using a paperclip. IF turn signal operation returns, column part is bad. PROMISE!!
And it may end up being your turn signal steering column harness in the column.
GM does that, ties all signals/lights operations thru the steering column part. EXCEPT headlight operation. Hi/Lo beam is in the column, tho.
I have to replace that unit on my 1974 Corvette & my 1968 Camaro.
Both of those turn signal switch units are worn out. I blow fuses & loose brake lights because of those two worn parts.
Old Dec 21, 2001 | 09:32 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
When you turn the signal on do they just stay on solid? My left signal did this.
It turned out that the plug in for the light was worn out. The parking lights were fine too. But the signal would not flash. So I went ot a junk yard, and got 3 or 4 of them for alike $5 took it home, cut the old one off, and wired on the new one. Problem solved.
Old Dec 21, 2001 | 08:50 PM
WaynesRS's Avatar
Karl , Tell Madrene , how pleased you are with that swap ! ...I know cus you have told me , but it means more when it comes from one who has done it ....I found this site for you madrene www.tacreationsusa.com.
this site tells you about it
Wayne
Old Dec 21, 2001 | 09:15 PM
I Cant Drive 55's Avatar
It could POSSIBLY be your turn signal switch.
If you turn signal on and the and it just stays solid then it could POSSIBLY just be the flasher . Sometimes the turn signal and the hazard lights are on differant flashers, but im not sure on the f-bodies because I have never had to change one on them.
Sorry but I see now that you say the switch is fine. How do you know if it is or not if the turn signals are not working
Old Dec 21, 2001 | 09:49 PM
Joe_L's Avatar
Car: 1995 Z28
WayneRS did you reply to the wrong topic. Because this topic has nothign to do with the 3.4L swap... just wondering, hoping this might clear things up, cause I had no idea what you were talking about either.
Old Dec 21, 2001 | 09:50 PM
Ping Wayne
Yeah Wayne you did have a good point about the wiring, you dont know what some people do when they are working on electrical problems . Sometimes they just grab a handfull of wires and pull .
This guy must have just had a bug up his a$$ or is just clueless about electrical stuff.
Old Dec 21, 2001 | 09:52 PM
Joe_L's Avatar
Car: 1995 Z28
Okay thanks for clearing that up C-valid I see what Wayne was trying to say now.
Old Dec 21, 2001 | 10:14 PM
WaynesRS's Avatar
But at the same time Madreman have some respect your a junior member, everyone makes mistakes, don't tell the wise ones on the board to shut-up .... or you will soon find yourself ignored.
Sorry bout that , I was telling him about the 3.4 b/c I was helping him in another post .He was asking about putting a 4.3 in his car .And most people on here know I think that the 3.4 is much easier ....Anyway, Again, I appologize for all that guys .It just makes me boil when people act like that .
Wayne
Old Dec 21, 2001 | 10:16 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Alright, i've seen this before and the flasher needed replacement. It's under the dash near the ALDL connector and it looks like a little silver cylinder. It has 2 prongs that are perpendicular to each other.....not parallel like your average home appliance.
Shouldn't set you back more than ~$8 from a parts store.
Old Dec 21, 2001 | 11:09 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Clean UP
I cleaned up some of the post on this thread. Please try to keep it civil. Thanks
Old Dec 21, 2001 | 11:25 PM
madreman's Avatar
turn signals...
thanks for all the replys......
ok, i installed a new flasher, i have tried another switch," just in case i got a bad one at the junkyard" . i went easy on unpluging the connector on the column, i would think the wireing to the bulbs are all ok, becasue i turned on my flashers , and all lights including the side marker lights flashed like they are supposed to.
when i turn the switch on, "to the right or left" nothing.. .... no lights on the inside or outside.
oh wyane,
sorry about before, frustration factor 9 on a scale of 10.
it just seems like i have checked everything.... twice and it doesn't make sense.
any help will do............
Old Dec 22, 2001 | 10:16 AM
KED85's Avatar
Outta sheer curosity
Have you changed the fuse in the box?
You have basically cut the ground, somewhere.
Where?
I mean if your flashers work, the wiring is good.
It's the turn signal wiring.
Electrical gremlins suck.
Old Dec 23, 2001 | 06:56 AM
Well I just had a brain buster.
The problem with your turn signals can be linked right back to the ignition switch. That would explain why your hazard lights still work. The turn signals need the ignition switch to be on to operate. The hazard lights dont.
Believe or not I have seen this before, but a long time ago on an older car, and the problem was the Ignition switch. (Not the lock and tumbler , but the switch itself)
Old Dec 27, 2001 | 07:38 AM
madreman's Avatar
thanks for all the help. i went to the junkyard one more time and they didn't have any good ones in any camero, so i looked around some more and found a pretty new looking one in a citation" is that how you spell that?" anyway, it worked. i grabbed 4 bad switchs out of cameros. they all looked good, but were crap.
Old Dec 31, 2001 | 09:27 AM
grimesjm1's Avatar
check your turn signal relay...i would bet that is your problem
Old Oct 27, 2007 | 03:56 PM
Sonicbluecamaro's Avatar
Car: 84 camaro z28
Engine: 350 Carb
Transmission: Built 700 R4
Re: turn signals
i have the same problem... Signals dont light up or anything, Hazards do. Can it be the turn signal switch>? These thread was confusing me since he switched out switch and didnt work and now it does?
and are the turn signal switch and flasher the same part? Just different names?
Old Oct 27, 2007 | 05:30 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: turn signals
Dude this is from 2001.
Old Oct 27, 2007 | 09:31 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Re: turn signals
doesn't mean a newbie doesn't have the same prob a few year later...
IIRC, there are two "flashers" 1 for the turn signals, 1 for the hazards. try swapping them to see if one of them went bad
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
