Vacuum lines
Old Aug 6, 2016 | 01:59 AM
GabeJMonster's Avatar
Vacuum lines
So I've searched through here for a few months for car advice, but find myself stumped so I finally created an account. The little vacuum lines that connect the egr and whatnot were cracked when I bought my 89 2.8. I've replaced them with pcv line and some pcv connectors and that's worked for now(besides trying to find connectors that fit perfect). Problem is to the little connector that goes just above/behind the throttle body broke. I shoved in some pcv connectors and that's worked, but now won't pass smog. My problem is, as someone who's learned about cars as mine has broke, I don't even know what this is called, nor where to find it. What I have found on here is that the preformed lines are pretty much irreplaceble because they're impossible to find. What can I do to replaced this? I check pick and pull regularly, but finding v6's is damn near impossible. Any advice? I'll try to post pics tomorrow of what I'm talking about.( warning the vac line job I've done is garbage, I've only been doing this for just under a year so trying to figure out the art of Macgyvering cars nicely is still coming along) plus this car was bought in fairly bad condition.
Old Aug 6, 2016 | 08:02 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Vacuum lines
There is a member on here called Knightrider. He has a 3rd gen junkyard and ships anywhere. look him up. I have purchased from him and is great to deal with.
Old Aug 7, 2016 | 05:12 PM
Buickstaged's Avatar
Car: 1984 firebird se
Axle/Gears: 373
Re: Vacuum lines
Gave, I too have purchased from Knightrider - great guy to buy from. If he doesn't have the part you need, PM me as I have a guy close to me that has about 30 cars that he has on hand. Local guy - good to deal with.. Best of luck - byron
Old Aug 16, 2016 | 06:32 PM
Re: Vacuum lines
Update: this is the piece that needs replacing. I have this, but I have little hard vacuum connectors going in. Apparently that won't pass the visual for smog.
Pillsbry10
May 28, 2016 03:09 PM
Calvin.w44
May 26, 2016 12:51 PM
xbmx89
South Central Region
May 23, 2016 12:22 PM
2012sergen11
May 20, 2016 07:36 AM
s19243h
Brakes
May 19, 2016 06:32 AM
