MAP SENSOR HELP
MAP SENSOR HELP
Hello there I have a 1991 v6 camaro I just bought while checking everything over I seen that the map sensor connector used to be is just metal connectors and wire if I buy a new map sensor which colors go in which order to make the sensor work properly I'm having an issue with it idling high
Re: MAP SENSOR HELP
https://www.corsa-technic.com/item.p...category_id=83
The high idle maybe a vacuum leak or iac stuck.
Re: MAP SENSOR HELP
Thank you I've been searching all over for this I really appreciate it and I went through and checked all vacum lines and redid the lines but it's still idling pretty high next thing will be Iac sensor like you said also like I said I just bought the car and don't have any exhaust hooked up could that cause the high idle as well
