Camaro 3.4 engine stall on load but re-start easyly and good idle . It rev up idle bu
I have a 3.4 manual 1995 camaro engine. . I can't push the throtle without engine stall. It run good at idle and I can speed up the engine normally. I trien to check it on a jack and when I touch the brake to put resistance to engine it's like I shut off the engine. It stall. But it restart easily and run good until I touch again the pédal brake exactly like I try to accelerate on the road. Same result, the engine stall. Is somebody can help me to find the trouble?
Re: Camaro 3.4 engine stall on load but re-start easyly and good idle . It rev up idl
[QUOTE=Marplant;6158624]I have a 3.4 manual 1995 camaro engine. . I can't push the throtle without engine stall. It run good at idle and I can speed up the engine normally. I trien to check it on a jack and when I touch the brake to put resistance to engine it's like I shut off the engine. It stall. But it restart easily and run good until I touch again the pédal brake exactly like I try to accelerate on the road. Same result, the engine stall. Is somebody can help me to find the trouble? 5 speed manual trans.
Stock 3.4 mpfi 5 speed manualswapped in my MGB who weight just 2350 pounds. Not for race just for the fiability and the nice looking as you can see if my attachement work. Thanks to help me.
I'm going to suggest posting over at 60degreev6.com, since neither your engine nor vehicle are 3rd gen related, I'm gonna have to lock this.
Looks good though, and good luck with your problem.
prostreetpop
07-10-2007 04:15 PM
