Upper plenum gasket
Car: ‘87 Base Firebird
Engine: 2.8 V6
Upper plenum gasket
Hey all, quick dumb question about the plenum gasket that goes between the upper and lower parts of the v6 intake plenum: if I take off the top part of the plenum (to access fuel rail for pressure testing) and then bolt it back on, will I need to replace the gaskets before running the engine, or can they be reused? I swear I read somewhere you had to replace them every time you pulled the upper plenum but I can’t find it anywhere. I have new gaskets already on the way but they’re a few days out and I want to check the fuel pressure and injectors asap.
Re: Upper plenum gasket
Engine: 2.8 V6
That’s what I get for posting at work when I’m not around the car! Easy as pie to get to. Thank you!
