nitrous kit
Car: 1986 Firebird
Engine: 2.8 V6
I'm sure a 50 shot would be fine. Your motor has the forged pistons (started in '89), so you're ahead of the game already. The one major killer of nitrous (besides too much for the engine to handle) is low fuel pressure- if the engine starves for fuel while you're on the juice, you'll burn (melt thru the center of) a piston. An electic fuel pressure gauge is the usual "safeguard"- if fuel pressure gets to be too low, you shut the car off and coast the rest of the 1/4 mile.
With Forged pistons you can run 75-90HP.
Begin by doing a complete tune up, new fuel filter everything. Get a MSD 6A ignition box too. Then get a boost a pump and you'll be safe to run 75, 90HP shots....
venom also makes a kit that works which cuts out when the mixture goes lean. look under www.nopi.com
Car: 1986 Sport Coupe
Engine: 2.8l V6
Transmission: 3 speed auto
here is my baby. how do i put it in the rides section
http://www.casgraphics.com/images/chriscamaro.jpg
it has
jet power pulleys
jet stage 2 performance chip
K&N air filter
flowmaster exhaust
richmond 3.73 rear end
transgo shift kit
it has
jet power pulleys
K&N air filter
flowmaster exhaust
transgo shift kit
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Pinguiclia
Oct 12, 2015 04:47 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
