z06 speedlines need spacers?
Old 07-01-2010, 11:02 PM
King NothingSS's Avatar
Car: 2001 Camaro SS
Engine: no engine yet :)
Transmission: T-56 with z06 drive gears
Axle/Gears: most likely 12 bolt or 9" with 3.91
these are the rims on my 2000 SS
i'm either picking up a 87 Z28 this saturday or i'm pickin up a 89 IROC and i want to throw these on since my SS has no engine right now, might as well use the wheels right? fronts are 265/40/17 and rears are 295/35/18. my question is will i need spacers for a stock height car or will i need spacers and what size if someone knows.
John
Old 07-01-2010, 11:52 PM
Stephen's Avatar
Car: 87 GTA
Re: z06 speedlines need spacers?
Yep.
http://www.skulte.com/adapterfaq.html
Old 07-02-2010, 02:07 AM
Car: 2001 Camaro SS
Originally Posted by Stephen
i have 1/4" spacers on my 4th gen so that write up should be changed cause if your lowered like my car your tires will rub. thank you for the link i'll post up pics when i get these on, i might just get the adapters so i don't run the risk of breakin the studs
Old 07-02-2010, 12:19 PM
Car: 2001 Camaro SS
which do most run though the slip on spacers or the bolt on adapters?
Old 07-02-2010, 01:23 PM
Stephen's Avatar
Car: 87 GTA
Bolt on ones are required. Your wheel studs are not long enough for the adapters to fit, nor would they be as safe.
But personally? I don't like even the bolt on adapters. There are safety reasons that some sanctioning bodies do not allow adapters of any kind in their racing.
Old 07-02-2010, 02:05 PM
Car: 2001 Camaro SS
thankfully it wouldn't be for racing, just for normal driving
Old 07-02-2010, 02:10 PM
Car: 2001 Camaro SS
anyone used these before?
wheels spacers adapter
Old 07-02-2010, 03:18 PM
AC
AC's Avatar
Car: Used to drive a camaro
Not that exact vendor but those are the sizes you need to run the wheels you're looking at using. Take pix after.
Old 07-02-2010, 03:32 PM
Car: 2001 Camaro SS
awesome!!!!! and pics will be up minutes after their installed
BrianChevy
Wheels and Tires
10-13-2015 12:33 PM
dbrochard
Exterior Parts for Sale
10-10-2015 01:03 PM
PAFORM350
Wheels and Tires
10-02-2015 07:21 PM
dbrochard
Wheels and Tires
09-25-2015 05:40 PM
xXIROC ZXx
Wheels and Tires
09-15-2015 11:18 PM
Quick Reply: z06 speedlines need spacers?
