Buying 17x9, 17x10 weld RT-S wheels soon - Need back spacing help pronto!
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I'm ditching my current 18's and going with some weld RT-S wheels in 17x9 front and 17x10 out back...quite frankly, I love the look of 18's but a car that can't get traction until midway through 3rd gear sucks to drive. With the 17's, I can put a bigger (and cheaper!) tire with some sidewall.
Now my HUGE concern is that I will be going with a 295/45/17 M/T drag radial, which is not a common size among third gens. My car is dropped about 1.75" and I need to know the best wheel backspacing to get this to fit in the wheel well. Weld lists the correct BS for that wheel on a third gen as 5.5, but I feel that will stick out too far for the size tire I'm going with. I was thinking something like 6" or even 6.5" would be a better fit, and tuck the tire into the wheel well more, but I REALLY need some opinions and advice here! It'd be a big bonus if I can get some pics from those of you who have a 17x10 wheel, and your BS specs.
Heres a few pics of my current setup. Rear wheels are 18x9.5 with 7.25" BS and a 1.75" spacer, which means that if they were correct third gen specs, they'd be a 5.5" BS...it just seems that with a 10" wide wheel, they will risk hitting the fender which I'd like to avoid. And preferably not hack up my inner fender well!
Anyways, thanks in advance all.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Buying 17x9, 17x10 weld RT-S wheels soon - Need back spacing help pronto!
A 295-45-17 tire is going to be 27.5" tall, about 1.75" larger diameter than stock 245-50-16 - lowering your effective gear ratio about 7% compared to stock tires.
I have never fitted such a size myself - others might be able to help. But the question is why not go 275-40-17 DR on the rear?
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 1986 Trans am
Engine: 5.3 LM7
So nobody has pics, BS info, or anything to help me out?? C'mon guys, I know theres a ton of people with 17's!
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
I would say 6.5 or 7" bs and some 315 35 17's would be sweet.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I just picked up a set of 17x9.5 with 5.25"bs.
No tires yet though.
I thought the slp 17x9" that used to be so popular had a 5.5" bs.
I had a 15x10 with 5" bs and 28"x10.50" slick on my car before. Fit but was close to the outside edge of the wheel opening.
My car is lowered as well.
I run a 17x9.5 with a 5.5inch backspace, and they fit with zero issue. They are flush with the fender flares. I'd imagine with a 10 inch width, you'd have to increase your backspacing by half an inch. Maybe minor hammering would be needed, and that's it.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I run 17"x"11" with 315s out back. Little hammer work, little cutting work, Adustable PHB & all is good out back. Even sits in about a full 1" from the fender lip.
Car: 1986 Trans am
Engine: 5.3 LM7
Heres some brand spankin new weld RT-S wheel pics for you guys and back spacing specs to help with your decisions.
Fronts: 17x9 with 5.2" BS & high pad height - no rubbing, and about 1/3-1/2" clearance from the tie rod. Tires are 275/40/17 falkens.
Rears: 17x10 with 6.3" BS & med pad height - There is a 5/16 spacer installed temporarily because the rims are too close for comfort to the bumpstops. I purposely sized them like this because I planned on modifying my bumpstops so I could "tuck" the big tire in the wheel well. Clearance is great with the spacer though, and the tires still do not rub the fenders! Tires are 295/45/17 M/T ET street II's.
Hope this helps you guys for any future sizing, since I know I had a hell of a time finding BS specs that worked. This was the result of A LOT of careful measuring all around!
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
looks much much better than your old ones yuck lol
now it looks complete
Car: 1992 camaro
Transmission: 5 speed
Sorry if I sound stupid but how do you figure out the back space you will need?
Car: 1971 Camaro
Engine: 427
^ try searching
Op, you had a chance to try these on the track yet?
Car: 1986 Trans am
Engine: 5.3 LM7
Car: '85 Z28
Looks like you got the back spacing perfect. Nice job!
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Pad hight on the rim what is that
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 87 iroc
Engine: 5.7 ZZ4, AFR, Stealth Ram, Comp cam
Transmission: 1993 T56 viper internals w Spec3+
Axle/Gears: moser 9" truetrac 3:89
sharp rims but what about the centercaps??
Car: 1986 Trans am
Engine: 5.3 LM7
Good point you made actually! Reason for the center caps not being on in the pics is because the "default" caps that come with the wheels are not deep enough to fit over the front hubs on the third gen spindles. I needed to order the longer center caps from weld for them to fit. I believe if you remove the metal dust cap from the spindle, the smaller center caps will fit, but I didn't want to take chances and provide an opening for dirt to get into the wheel bearings.
Heres a few more recent pics of it with the longer center caps on! Don't mind the rims being a bit dirty in these pics. I tend to drive more than clean lol.
DR is Drag Radial.
I've always liked the look of the Weld RTs and am thinking of getting a set myself. I also like the option of going to a larger tire should I want to.
My question regards your "dropped" height. Do you have measurements from the ground to the fender lip, front and rear? I'm running a 2" dropped spring (Intrax) and I look to be quite a bit lower than lower than you. (I realize the 295 tire adds about about 3/4"-1" at the back.)
Thanks.
Looks good.
Thanks.
Looks good.
Car: 1986 Trans am
Engine: 5.3 LM7
Thanks.
Looks good.
Thanks.
Looks good.
I read stuff like this a lot, but it doesnt make sense to me. 40 series on a 16/16/17/18/19/20 inch wheel with 245/275/315 etc tread widths is going to vary wildly. Is there something to the width of the tire making the sidewall stiffer so that regardless of what size wheel and width tire you run a "40-series" will have roughly the same characteristics?
Either way, I think 17's tend to look a little more balanced and Weld RTS's are an amazingly strong, lightweight, and attractive wheel. The car is going to look amazing with them.
Car: 1986 Trans am
Engine: 5.3 LM7
Oh, and the weld RTS wheels are already on the car too
See a few posts up for the pics!
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Would 6.5 backspacing be a big difference from the 6.3? Or would it be the same as the pics because you have spacers on it
Car: 1986 Trans am
Engine: 5.3 LM7
Actually, the fact that I have the spacers makes the backspacing more like 6" since it pushes the wheel outwards more. I believe 6.5" backspacing is very common on a 10" wide wheel, and there's a ton of guys that run that size on a third gen. If anything, you may have to cut out your bump stop in the wheel well, but that sizing should work great.
Engine: 4++,350 & 305 CIs
Those new wheels look great!
Do you have any pics of how far the front wheels stick out from the car, if any? I just bought a set of Weld RTS wheels and went with 17x8s in the front with 4.7" backspacing (5mm offset).
The inside of the wheel is about 1/4" away from the strut and I'm running C6 brakes which pushed the wheel out slightly. They still sit flush with the fender but I'm now wondering if I could have went with the specs you used and still been good. Im not changing right now since it will be a $1300 change!!
Car: 1986 Trans am
Engine: 5.3 LM7
Thank you sir!
Hopefully these pics give you an idea. They sit perfect IMO. Mine are 17x9 though, so in order for yours to sit at the same point at the fender lip, you'd have to go with 4.2" backspacing. I run C5 brakes so mine are slightly pushed out as well compared to stock. 1/2" off is going to be barely noticeable though honestly, and as long as they aren't hitting the strut, you're golden. The wheel moves in conjunction with the strut so you won't have an issue.
kah992
08-19-2015 02:55 PM
