Hawks Ronal R-15 18x10 Reproduction Poll
#53
Re: Hawks Ronal R-15 18x10 Reproduction Poll
This solidifies my vote for A. Maybe not as a true R15 replica. I like the look and the lack of any cap makes the exposed lugs easier to check and re-torque at the track or for tech inspections.
Thanks Hawks for continuing to do research and development for this generation of car!
#54
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Everyone should be grateful that Hawks supports our cars down to the last detail. Thank you guys.
#55
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
It’s too bad they can’t make both.. I’d say A is better for the track and looks like a whole new type of wheel, but B has that period correct iconic look people will want for a show car..
Could just take the caps off on track days with B..
#57
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
the open center doesn't look right to me
closed one is a gooooo
#58
Car: 2002 Camaro SS
Engine: Built LS
At the end of the day for me, the brake clearance is what's going to matter for me. I know the 17's clearance isn't great.
#59
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
COTM Editor
#61
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
RE: It’s too bad they can’t make both.. I’d say A is better for the track and looks like a whole new type of wheel, but B has that period correct iconic look people will want for a show car..
I think that was the best post in the thread. 88IROCvertZ hit the nail on the head. If you made A with an optional cap, people could choose. If you wanted B just put the cap on it and the detailed center is covered.....
#62
I agree with option A with a removable cap to look like B. However I'd vote for A but in a 10.5 or 11 for a track wheel. Also needs to be under $500 a piece.
#64
I am going to go with A, it just looks more modern to me if you/someone is trying to go for a more updated look. More period correct is version B which seems to have the older crowds attention. That's just my two cents, but what do I know?
#66
Axle/Gears: 9-bolt/3.45
Wheel A looks like a generic SLP-styled 4thgen reproduction wheel, not the 3rdgen R15 Firehawk wheel.
If there's a real need for an 18" R15 Firehawk wheel, then wheel B should be it. Otherwise, why reproduce it?
#67
Are people who are shopping for an 18x10 wheel that concerned about being truly period correct? That seems to be more in the pro-touring or track day category, and I have a feeling those guys would prefer option A. I'd think the period correct crew would want a 17x9.5 Ronal...
#68
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I think the Ronal is one of the best looking wheels to ever grace a Firebird but it won't fit over most (all?) larger than stock brakes. The 18" wheel will be useful for added brake clearance. Period correct and original don't matter much to people like me -- It's just a damn good looking wheel on a 3rd gen.
#69
- Rob
The following 2 users liked this post by Street Lethal:
1986BANDIT (12-28-2019), Ed1LE (02-27-2020)
#70
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
There already is a reproduction 17x9.5" wheel. This is so you can get more brakes and better tire selection and staying with a wheel that looks period correct, well the option with the closed lug anyway.
I have had my Ed Miller 12" FSL Wilwood setup behind my original R15s, not sure how much more I could fit though, I don't have anything in 13"
That's exactly my thought. Why even call it an R15 with the open lug? It's not the same look without the closed center, so why even consider calling it that?
#76
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
I will third that I am ready to purchase a set I would even take some prototypes if you have a set
#78
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You can call Bruce right now and he'll have Forgeline make you a set. It's the cast aluminum version that is still yet to come. You can get 'em on order now if you prefer a forged wheel.
#79
Car: 92 Firebird
Engine: 4.8 LR4
I got their mailer just a few minutes ago. They changed the design of the spoke, they narrowed it in towards the hoop. It doesn't look right to me even with the closed center. Was so excited for them, now not so much
https://www.hawksmotorsports.com/198...brake-capable/
[img]https://cdn2.bigcommerce.com/server2...0.1280.jpg?c=2 [/img]
#85
But the 989$ price tag was a dropped price from the original asking price of around 279$/each without the center cap and emblem! I know the 1500$ is high but at least we can get a 3rd gen wheel set without running any adapters!
And as for the thinner spokes, I think they re-designed them in order to show more brake system than the OE Ronal? Now we just need to know which options are available as for painted or polished windows...
#86
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I wouldn't mind rocking a set of those wheels with red accents for cruise nights! Black Friday sale is coming up, gents.
Question for Hawks: what is the backspacing? Is red accents in the works?
#87
Which tire size would you run? I don't want any rubbing issue on the front so I was thinking some 275/35/18 for the fronts and 295/35/18 for the rears.
I search for the widest tires that can be mounted on the 18X10 rim and ended up in a LS1 tech forum saying that some guys are running Nitto's 315/30/18 on them!! And apparently depending on tire brand, with the 275's the lip of the rim comes past the tire!? I am tempted but don't want to roll the fenders and I have a 1" drop springs too...
#88
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
b
make A as a completely different rim OR make it so you can run them either way
#89
Car: 1986 trans am
Engine: 305/350
either works,prefer the original design
#91
Car: 1986 trans am
Engine: 305/350
and now they are offering 18" possibly,why change the style to be a non-ronal r15 rim? there are enough random oddball rims for these cars
1)keep the ronal r15 looking like a ronal r15
2)offer both
3) make the open center round and adaptable to proper appearing centers(that would be the intelligent thing for hawks to do)
2)offer both
1986BANDIT (12-29-2019)
#93
Any news on these wheels? Still says preorder only with an estimated ship date of December 2019 . Also interested in the 91-92 Z28 wheels in 17" that Hawks is supposedly producing but getting any kind of answer from them is proving difficult.
JTome91z (03-19-2020)
#95
Premium Sponsor
Good afternoon, all!
They're in production and estimated delivery is the end of February. We apologize for the wait as we encountered some delays due to COVID. Rest assured that we are working hard to bring them to market ASAP!
Side note- at the bottom of our website you can subscribe to our weekly e-newsletter. We announce all of our new, and upcoming reproduction items there first for subscribers.
The following 5 users liked this post by hawksthirdgen:
BizJetTech (12-04-2020), freaky (12-11-2020), Jaysz28 (12-06-2020), punkmaster98 (12-05-2020), TTOP350 (12-05-2020)
#96
Car: 90 Formula / T-tops
Transmission: MD8
wheels look great! at some point, I will be begging for Formula wheel repro's. - when those 16" tires disappear from the market.
rt66er (12-06-2020)
