Flowtech Y Pipe
Old Feb 9, 2003 | 07:30 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
Flowtech Y Pipe
Do the Flowtech headers come WITH the Y pipe in for the 90$ or is it sold seperately?
Old Feb 9, 2003 | 08:27 PM
darbleinad's Avatar
Car: 84 Trans Am
it is sold seperately. the headers come with bolts and collectors and some crappy, crappy gaskets, but no y-pipe.
Old Feb 9, 2003 | 08:38 PM
Car: 1986 IROC-Z28
How much more is the Y pipe?
Old Feb 9, 2003 | 08:42 PM
darbleinad's Avatar
Car: 84 Trans Am
thats a good question...i never bought it. i think its about the same price as the headers if i remember correctly. these are a great header for the price and work real nice on a 305.
Old Feb 10, 2003 | 10:59 PM
Shagwell's Avatar
Car: projects.......
Good headers for the money. I didn't think the gaskets were bad. The y-pipe is seperate, but its a turd ball. its just like the stock pipe, it "T"s on the passenger's side. I had a y-pipe built using a Flowmaster y-pipe.
later, justin...
Old Feb 16, 2003 | 10:20 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
my y pipe from summit was like 85-90 bucks. its pretty crappy too, i had to put a jack under the exhaust and jack it up where it connected to my cat and and put some steel straps on it to keep it from making my cat drag the ground. i dont know if i just got a bad one or if they are all made that way? and yes it does make a T , but it works for me, when it rusts out then ill have one made. but i like the headers, they seem to be good for the money. they fit good, work good, header bolts r a pain and plug wires have to be routed really carefully but im happy with them. the gaskets are crap too, i just used a set of felpro drop ins i had laying around and they work good.
Old Feb 17, 2003 | 09:16 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
I priced up a pair of Flowtech headers and I asked for the set that came with the ypipe,,,,The guy at the counter said that the catolog listed headers including long pipe. Is a long pipe, what flowtech calls a y pipe????
Old Feb 20, 2003 | 10:32 AM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
It looks more like a Y pipe and not a T pipe. It doesn't appear to follow the stock routing, but go under the car, giving up clearence resulting in banging around, etc. It costs roughly $100
http://www.holley.com/HiOctn/ProdLin...SFT/Ypipe.html
Old Feb 20, 2003 | 03:22 PM
bad_ta_05's Avatar
Car: 85 trans am
i thought the flowtech y pipe looked like that too, thats why i ordered it, but it looks nothing like that. its a shiny cheap steel and it is a T, looks just like the stock one but a little bigger.
Old Feb 20, 2003 | 03:31 PM
darbleinad's Avatar
Car: 84 Trans Am
first off that picture is not of the f-body y-pipe. that picture is of a y-pipe for 88-95 chevy pickups (2WD/4WD). they dont have a picture of the f-body one that i can see.
Old Feb 28, 2003 | 11:33 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
http://www.holley.com/HiOctn/ProdLin...f16102FLT.html
pic of the camaro headers with y-pipe.
Old Mar 1, 2003 | 01:00 PM
bad_ta_05's Avatar
Car: 85 trans am
thats not the y pipe, it lookes a little like the headers but nothing like the y
Old Mar 1, 2003 | 01:45 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
thats the same pic that i see at summit's site. they have the whole kit for 210.69 part# is BIG-16102. check them out, do think these would work nicly on a mostly stock 305
Old Mar 1, 2003 | 05:06 PM
crazycamaro's Avatar
Car: 89 RS..97 RS..85 Dodge PU
Engine: 89=377,,,97=V6,,,85 PU 318
Transmission: 89=TH350,,97=T5,,85PU 4 speed
This is the same set that I have on my 89 R/S but the end of the pipe is a lot longer, Easy install & been on for over a year and never have draged on anything "normal"
Old Mar 2, 2003 | 12:02 AM
Engine: peanut LB9
hey crazycamaro, how do you like them. is there anyproblems when u instlled them and on what motor
Old Mar 2, 2003 | 09:26 AM
No problems I had the starter out and if I did'nt hold them up where they go they would fall clear through,so you can put them in from the bottom or from the top I put them in from the top.
Old Mar 2, 2003 | 09:36 AM
Engine: peanut LB9
thanks thats what i wanna here
what size is the Y-pipe before and after the y?
does anybody there emissions headers and if so does anybody have a pic?
Old Mar 2, 2003 | 09:40 AM
It is 2 1/2" all the way, The driver side has a place to put the oxygen sensor but i'm not running any computer,but it is there if you need it.
Old Mar 2, 2003 | 10:03 AM
Engine: peanut LB9
what about air tubes, ithe summit catlog they say they have the flowtech heade and y-pipe that are emissions legal expt for cali,
summit part #-BIG-16102 there 210.69, i'm curios if anybody has them. cause ifyoubuy the regular flowtech heaers they are 90 and the y pipe is 90 to sois when u combine the two they ae 30 more. so i think they have the air tubes or something else.
Old Mar 25, 2003 | 09:14 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
yea, that link I posted is not a pic of the camaro headers or the camaro y-pipe. It is the link that flowtech says is, but I just bought a set from killjoy, and that ain't them. Looks like they just used a generic picture for their link.
Old Mar 26, 2003 | 01:43 PM
Car: '81 Trans Am
Engine: 6.6L
Yep I bought a set of flowtechs and instaled them myself last week. That link is not a pic of camaro ones, headers and ypipe are different.
My ypipe wasnt even painted at all. And the o2 sensor mounting point comes pluged and to use it you got to drill it out (but the treads are there.
I only had to remove the old manifods and the ypipe to put mine in and I unhooked a few rear plug wires to drop them down from the top,,,,I didnt even take off my starter.
I thought the gaskets that came with it were fine,,,,they were paper but had metal samwiched in them so they cant be that bad. I dont notice and leaks yet.
Last summer I had them cut out my cat and put in a pipe,,,,all I did was cut it alittle shorter and clamped the flowtech ypipe over the pipe they used instead of a cat.
I also thing the ypipe is more of a "t" then a "y" but i dont mind. Overall I was pretty happy with them but i wish the ypipe was painted like the headers but its cool.
If you buy just the headers they still come with lower gaskets and bolts and the 2 flanges that you use to make your own ypipe. I opted to get the ypipe so I could bolt up everything myself.
Old Mar 27, 2003 | 09:45 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Man these sound like a really great buy!!!! Do any of you who have the flowtechs installed have pictures of them in plus the Y to gives all a glimpse as to what they really look like
flowtechs= ...lol I dont know maybe though?
Old Mar 27, 2003 | 10:10 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
1.5" primaries, 2.5" collectors, and 2.5" ypipe. Everything is pretty small as far as headers go, but I'm guessing that they are a little easier to work with. I installed a set of Hedman or Hookers a number of years ago with the 1 5/8" primaries and 3" collectors and those took about 12 hours to install because the engine had to be unbolted and jacked up to fit the drivers side header in.
Old Mar 28, 2003 | 10:06 AM
jeffs82z28's Avatar
I have the Flowtech's and they work pretty good.
They have 1.5" primary tubes and the Y-pipe is kind of a turdball, but for us poor (cheap bastads) they are all right.
I'm going to re-use them when I install the 350.
I'm going to be working under my Z this weekend and i'll get some pics.
The only time I've scraped anything was when I Banzia' d through an intersection and caught some air time
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
