looking for the best afpr
Old Mar 12, 2004 | 04:01 PM
mikobu3's Avatar
what is the best 1 out there for the 1986 305 tpi thanks
is hypertech any good?
Old Mar 12, 2004 | 04:46 PM
irocing's Avatar
Car: 1987 IROC-Z
Engine: stealth ram injected ZZ4 350
Transmission: 700R4 w/3200 stall
Re: looking for the best afpr
I think that the best afpr by experience and by word of mouth is going to be a TPIS afpr, i had one on my 87 IROC and it worked good, but then my buddy has a Holley on his 88 IROC and he very pleased with the way that it worked. But i think that the best bet is go with the TPIS. Best of luck!!!
Old Mar 13, 2004 | 01:31 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Holley is the only one I know of that makes an AFPR that uses a dial to make adjustments. The rest use a bolt sticking out of the top of the AFPR which for most makes it harder to adjust because its either too close to or it hits the plenum.
Old Mar 13, 2004 | 09:59 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
go with the holley......no more wrenches........
Old Mar 14, 2004 | 12:39 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i went with the holley, and im glad i did
Old Mar 14, 2004 | 06:08 PM
mikobu3's Avatar
thanks guys i will go with the holly
anyone got the part number for it
thanks again guys
Old Mar 14, 2004 | 07:29 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
All AFPR are worthless......get into chip burning and you'll see why....
Old Mar 14, 2004 | 09:11 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
thanks again guys
The part # is 512-501.
Old Mar 15, 2004 | 12:37 AM
It wouldnt hurt to tell us why would it? Do you have AFPR on your HSR?
Old Mar 15, 2004 | 11:56 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
no AFPR on the stealth ram....all fuel tuning is done in the PROM.
Old Mar 15, 2004 | 12:48 PM
cmeyer's Avatar
Car: 70 Camaro RS
It's true that you can increase the amount of fuel being delivered by the fuel injector through programming, but at some point you'll be pulsing the injectors at more than 85% duty cycle, which is the upper limit of the fuel injector. Any duty cycle higher than this will drastically reduce the life of the injector. By installing a fuel pressure regulator you are effectively increasing the flow rate of the injector and can deliver more fuel per pulse width.
Hope that made sense.
Chris
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
