Will a Hypertech chip work for my car until I can learn to burn my own chip??
Old Jan 26, 2001 | 12:39 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm starting my 383 Stroker TPI project soon and I know I'm going to need a different chip in my car! I don't know anything yet about programming my own chip so I'm wondering if a hypertech chip will work for my car until I can learn to burn my own chip?? Here's the basics of what my engine will be.......383 Stroker w/TPI, headers, Aftermarket 64cc heads with a 200cc runner, port matched intake, street/strip comp cam, TPIS airfoil, adjustable fuel pressure regulator and 24 lb/hr injectors!! I know that everyone here is going to "recommend" a custom chip but I know this already! I just plain and simply want to know if I can use a Hypertech chip UNTIL I can get a custom EPROM!
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, 64cc Pocket Ported Worlds Product Sportsman-II heads, ported intake, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Old Jan 26, 2001 | 12:44 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're better off with the stock chip, because the Hypertech chip wont make your car run any better than it will. Save your money.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 26, 2001 | 02:54 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree with Kevin, these "off-the-shelf" eproms do very little. You will accomplish more by modifying your fuel pressure and adjusting the base time using your stock eprom than any "off-the-shelf" eprom.
The two biggest changes I see that you need done quickly is 1) adjust the Cylinder Volume of your engine for the larger displacemnt and 2) adjust the Injector Flow Constant.
Old Jan 26, 2001 | 03:43 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Save your money. I agree. Hypertech chips will do nothing to help in the areas that you need help due to the mods that you have.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
Moderator: PROM board at thirdgen.org
Program your own PROMs. Read my article on how to do it!
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
