still running mafless...
I just went on a trip, it was 220 miles one way.It's a very tired 305/tpi, my red car. The old bird cracked the 200,000 mile mark on the way home. I have been running a 165 ecm w/o a maf sensor for some time now, as you might remember. I have made a few changes to get it running fairly well. Closed loop and all. THe a/c was on and the car was loaded to capacity..
THe averages was,
24mpg
84mph
170 coolant temp(steady)
80-90* ambient temps
Not bad for an old motor,heh? Wonder what kind of mpg a strong 305 TPI would pull down(w/ working maf and ecm tuning)?
THe averages was,
24mpg
84mph
Re: still running mafless...
Mods to my 86 T/A:
91 firebird 305 TBI engine/w
Ported factory TBI heads
Comp Extreme Energy cam (212/218*_509"/530"_112*)
1.6:1 stamped crane rockers
stock LS1 injectors
1-5/8" long tube headers
SLP loud mouth cat back (w/o cat)
MAF delete pipe
My stock TPI intake (slightly ported)
LT1 valvesprings and retainers
Here is the key. I'm running w/o the MAF/MAP, O2, KS, MAT and all the emissions equipment. That really just leaves the CTS, TPS and RPM and the only ECM inputs. AFR is in the high 14's/very low 15's durring most of normal driving. I just need to remember the locations to to add the default airflow table to tunerpro(again). Once that is done, I will be able to increase MPG beyond 26. I have logged about 130,000 miles in alpha-n and don't see any reason to change.
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Until your weather changes, or you go up a mountain. Then you'll be hurtin for a MAP sensor.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The code for the TPS based redundant fueling in the TPI ECMs is extremely crude at best. Its literally like 20 lines of assembly and only uses the TPS and IAC flow to estimate the default airflow. Basically, its there to get you off the road, or to a shop.
If it where me, Id hook up the MAF, or go speed density.
Car: 88 Camaro SC
Engine: SFI'd 350
Heres the alpha-n code from the $6E... Alpha-n can be made to work well, but it would require, at the very least, baro and IAT compensation.
Code:
F92E: LDAA L0058 ;RPM/25 F930: LDX #$C222 ;DEFAULT AIR FLOW OFFSEt F933: JSR LF3F8 ;Go do lookup F936: LDAB LC21E ;If TPS GT 65.2%, then use for MAF Default F939: CMPB L0083 ;%TPS F93B: BCS LF93F ;bra if %TPS is greater ; F93D: LDAB L0083 ;%TPS ; F93F: LF93F MUL ;%TPS x flow factor vs rpm F940: STD L00F1 ;Save it F942: LDAA L002B ;IAC position F944: LDAB LC21F ;IAC airflow scalar F947: MUL ;Scalar x IAC position F948: ADDD L00F1 ;Add it into the airflow F94A: BCS LF951 ;Bra if overflow ; F94C: ADDD LC220 ;Add in airflow offset F94F: BCC LF954 ;Bra if no overflow ; F951: LF951 LDD #$FFFF ;Clear overflow F954: LF954 JMP LF9B0 ;Bra to save and continue
Car: check
Engine: check
Transmission: check
It is actually quite surprising how well they run in N-Alpha mode. The malfunction code creates an airflow value instead of the MAF, and everything else is the same.
RBob.
RBob.
On our ECU we run alpha-N for limp home, and just have a new table that converts TPS vs RPM to a MAP value, and the lookup is done on the VE table. IAC is very important (especially with AC on/off), but we haven't added it in yet (software guy says the customer should just take the car to get it fixed).
The alpha-N works great at one altitude. Works like poo on a real mountain. Wish there was some legitimate way to take the fuel adapt value to estimate BARO... Maybe there is... But, the Alpha-N needs the opposite effect to fueling - whereas if in SD, more VE is needed at high altitude, but alpha-N gets to be soooo rich.
Car: 88 Camaro SC
Engine: SFI'd 350
The question is not why, but why not?
Car: 2000 BMW M5
If you have some bad feelings about MAFs, why not convert to MAP? Did a MAF sensor scare you when you were a kid and you have lasting hurt feelings over it? I mean, you can run a carb if you really want to, it just depends on how much fuel trimming you want.
Hehe, 2000 ft??? That's nothing (just messing with ya).
Just a little about what a real mountain pass (with a road) that we test on is about 5000m (meters) (over 16000ft, and 52kPa Baro). That's high enough to make you literally feel high, and sometimes want to throw up. The car does too, when in alpha-N (that was calibrated at sea level).
As long as your standards of what's good enough are low enough, alpha-N works fine. I've done a few in the US as alpha-N, and no complaints (and no IAT, just TPS and CTS, like on a IR 502/502 but not with GM efi). Low throttle is the hardest part, though, and any throttle or TPS adjustment requires a retune or other adjustment.
But, big cam guys that race and don't drive a lot may find Alpha-N to be much much easier to deal with, and I wouldn't blame them. It's simple to understand, and simple to tune. And if they run a wideband, they can make a simple adjustment if the weather causes any problems.
Car: 88 Camaro SC
Engine: SFI'd 350
If you didn't post that, I might of needed my flame suit. The above quote is DEAD ON. I have alpha-n running VERY well. Over 100,000 miles. 26 miles per gallon. I do not need to touch the accelerator pedal on cold starts. Idle is rock solid. DA can swing over 2000 feet in one day around here, easy. I think it was last week and 78*F, the next day 30*f.
One thing about a stock or near stock engine is that its surprisingly tolerant to AFR fluctuations. Itll run at 16:1 and at 12:1. Ive even run mine at 20:1 at WOT by mistake. Doesnt make much power, but it runs... The big advantage to accuracy is that the engine runs smoother and more uniformly if the AFRs are on target and dont vary over the short term. I found real gains by getting the fueling to within +/- 2% of my desired AFR over most of the engines operation. This and it performs the same each time I jab the gas down. Right now its just in the ballpark. Sort of like what youd get with a holley carb. If thats the way you like it, then hey, run with it. But, with a better algo, I think you could get much closer. JMO
Car: 88 Camaro SC
Engine: SFI'd 350
Not flaming you, BTW. Just a bit opinionated like everyone else on this board.
Also, FWIW, I too use alpha-N, but during transitions. There is a phase lag in the MAFs response due to how a frequency based MAF system works. During the first 1/4 of a second during tip-in, the reported airflow is way behind the actual airflow. On tip-in, I use a delta TPS term along with the IAT and baro TPS compensation to construct momentary delta TPS based fueling to cover for the transitional airflow. Without it, the engine backfires on tip in and goes dead lean for a split second.
Also (11's), I'm not flaming with what I mentioned in previous posts too
, and hope any criticisms or other views are constructive! Re: still running mafless...
..AFR is in the 14's everywhere but WOT. That is my standard...
I can manually change the calibration when I make that 16,000 feet journey, lol. Seriously, does your car run much better than described above?
EFI is the only way to go. I'm here to say the MAF vs SD wars are old news. No load sensor is the new front.
Car: 88 Camaro SC
Engine: SFI'd 350
The short AE based on alpha-N lasts just a few hundred milliseconds to cover for the momentary lean spike. Without it, there is a loud snap out the intake on fast tip-in from being super lean for a split second and then the car goes normally.
Car: 88 Camaro SC
Engine: SFI'd 350
A basic carb will also work well, but the fueling wont be accurate. One thing Ive discovered is that the accuracy of the fueling is proportional to the complexity of the software model controlling the fueling. You can have a simple model, but it will only approximate the fueling. You can have accurate fueling, but this requires a complex model that can accuratly estimate the fueling needs of the engine over a broad range of operating conditions. Regardless of whether its MAF, MAP, or alpha-N, the simpler model will be easier to tune, but more rough. The more complex model will provide accurate fueling, but be harder to tune. In the end, its sort of a balance between the two.
Car: Death Mobile
Engine: 666 c.i.
Car: Death Mobile
Engine: 666 c.i.
On a technical note, I think its rather clever for a person to "tune around" an inoperative sensor (regardless of sensor) and actually maintain a good state of tune.
One never knows when a sensor may fail, one is not readily available and a person needs to keep the vehicle operating. Especially if it is their only car (as is the case for some members).
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
