Sample VE Tables
Old Aug 18, 2003 | 09:52 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Sample VE Tables
Could some people post thier VE tables either in a plot form or table? I know that every engine will have it's own unique table and I don't intend to copy the table or base mine off of it. I more or less want to see the shape of a table with a better intake, cam, exhaust, etc. I'd also like to see if moddified tables are as smooth as the stock one. I searched, but you can't search for VE and there didn't seem to be alot of results for "table".
Thanks,
David
Old Aug 19, 2003 | 10:18 AM
Doctor J's Avatar
Here is a stock L98 VE chart:
Old Aug 19, 2003 | 10:20 AM
Doctor J's Avatar
Here is an L98 with larger cam, intake, headers (and you're correct, you can't just copy from one engine to another - your VE needs to match your particular installation):
Old Aug 19, 2003 | 10:51 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Big cam, MiniRam ....
t
Old Aug 19, 2003 | 05:10 PM
Thanks I appreciate the posts. What do you do to get the table that smooth? I'm trying to get a smooth curve like that but both of you are far ahea of me.
Old Aug 19, 2003 | 06:04 PM
TRAXION's Avatar
Click and drag ON THE GRAPH. The graph can be manipulated directly by clicking and dragging points on the graph.
Tim
Old Aug 19, 2003 | 06:45 PM
Oh..I think that came out wrong. But I guess it still answers my question. So you get all your data points in and then manually smooth it. It didn't know if you were using and special software or weather TC had a smoothing function in it. I'm still tunning with GMECM so no dragging for me
David
Old Aug 20, 2003 | 05:28 AM
JohnL's Avatar
I'm still using GMECMEdit v2.10 and it has click and drag VE's (although 2D). Cool, and will be even cooler when it's 3D
John
Old Aug 20, 2003 | 06:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
David
I've used two methods to smooth the VE tables. One is to read (import) the VE table into Excel and create a surface graph from it. Locate the high/low points and make a change to the data. As the data is changed it will show up in the graph to visualize.
The other method is to use a graphics tool and to use the smooth function. Read in the VE table as a gray scale image (IIRC) and have at it.
RBob.
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
antman89iroc
DIY PROM
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
DIY PROM
Sep 17, 2015 07:48 AM
ULTM8Z
DIY PROM
Sep 16, 2015 09:15 AM
