where is the speedo buffer box?!
Old Aug 6, 2004 | 01:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
where is the speedo buffer box in a 91 camaro?
does anyone have a pinout for it?
specificly, i intend to try somthing suggested by another member.
im going to take the "to speedo" wire and connect it to the same pin as the "to cruise control" wire.
the cruise control works of half the PPM (pulses per mile) of the speedo.
this SHOULD effectively make my speedo read half of my actual speed.
i'll then swap gauge faces from a 110 speedo to a 220 speedo.
Old Aug 6, 2004 | 01:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello MrDude_1,
While I don't have the manual for the 91 at the moment, I do have the manual for the 92 camaro. In the 92 models, the only engine that had the VSS buffer box was the 305 TBI and it was located under the dash next to the ECM. The other engines operated off the VSS on the transmission which was a two wire affair going to the ECM.
Old Aug 6, 2004 | 01:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by Trickster
Hello MrDude_1,
my car was a 305TBI so thats what it had....
so its a yellow box next to the ECM...
by any chance can you tell me the wiring pinout/colors going to it?
Old Aug 6, 2004 | 02:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes I can, better yet I will send you a schematic of it. Is this more along the lines of what you are looking for?
Attached Thumbnails where is the speedo buffer box?!-gle-ensor-permanent.gif
Old Aug 6, 2004 | 02:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
PERFECT!
thanks Trickster!
ps: why dont you add "The Trickster!" to the end of every post anymore?
The Dudester
Old Aug 6, 2004 | 02:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
See sig above and getting lazier in my younger age.
Old Jul 14, 2005 | 04:12 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
Hey Trickster, is there a way to wire it to remove the buffer box completely? I switched from 305 tbi to 352 tpi w/7730 ecm.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
tattmann
Sep 27, 2015 05:20 PM
