Could someone explain blm a little?
Old 05-01-2002, 03:26 AM
Arawn's Avatar
I've seen peoples numbers and have a general idea of what numbers are good and bad. But could someone explain in a little more detail what it is and what the numbers relate to. thanks
Old 05-01-2002, 08:32 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Your ECM does a calculation for how much fuel the engine needs. It takes sensor readings, and the cross references them to tables in the chip. In the case of your MAF car, it measures the airflow, then looks at the tables to see how much fuel it takes to get the right air / fuel ratio (AFR). It then injects that much fuel.
In closed loop, your ECM is also taking readings from the O2 sensor. Your ECM's goal is to keep the O2 switching back and forth around a rich / lean point, so that the average AFR is right on. Your ECM keeps track of the average amount of fuel it is injecting to keep the AFR around that rich/lean switching point. If the value for fuel in the table is making the O2 sensor show lean, your ECM adds more fuel. If the O2 is rich, it takes fuel out.
Now on to BLMs, the Block Learn Multiplier. Like i said, the ECM has tables in the PROM that tell it how much fuel to inject @ a certain RPMs and a certain airflow. These tables are divided up into 9 sections or BLOCKs. Also like i said, your ECM keeps track of how much fuel it needed to inject to keep the AFR correct, thats the LEARN part. The MULTIPLIER is how much fuel the ECM had to add or subtract in that BLOCK to keep the AFR right. Each BLOCK has it's own BLM, so that it will have one number each for low-mid-high rpms, @ low-mid-high load.
As you probably know, BLMs will be a number between 108 - 160, and 128 represents the 'ideal' BLM. Now let's say you have a scan tool and you notice all your BLMs are high, let's say they are all around 144. That means that your ECM is adding 144/128 more fuel to what the tables say you need. If the tabes say you need X fuel injected, BLMs of 144 means it is actually injecting 144/128 or 1.125 * X fuel. If your BLMs are 110, it is injecting 110/128 or 0.85 *X fuel. You can see why a BLM of 128 is perfect, 128/128 = 1, and 1 *X = X, wo that means the tables have the right value already.
Hope that helps...
Old 05-01-2002, 09:31 PM
Arawn's Avatar
*applauds* Thanks, that was crystal clear to understand Sorry for making you type so much for my dumbass though
Old 05-01-2002, 10:32 PM
Ed Maher's Avatar
Car: 04 GTO
NP, i'm sure you're not the only person thats going to read it
Old 05-01-2002, 10:51 PM
Arawn's Avatar
Hehe. You just made it into my "Vader and other people who know to damn much" clip book To bad my last hard drive died. I had some really usefull stuff saved up from 2 years of the message board and about a year of the s-series mailing list before it switch to a message board and went down hill...
Pac J
05-17-2020 10:44 AM
Ed1LE
09-30-2018 09:14 AM
Mark_ZZ3
05-24-2018 01:02 PM
antman89iroc
DIY PROM
36
01-31-2016 08:42 AM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
Quick Reply: Could someone explain blm a little?
