how hard to change speedo from 110 to 145
Old May 18, 2002 | 10:54 PM
Brendon's Avatar
how hard is this swap on a 92 camaro? thankjs
Old May 18, 2002 | 11:26 PM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
you can just plug the new cluster right in. no other changes needed
Old May 18, 2002 | 11:28 PM
Brendon's Avatar
what do i have to take out to remove the old speedo and how long will it take?
Old May 18, 2002 | 11:37 PM
Twistopher's Avatar
Engine: 305TPI
I am not sure about just doing the speedo. You are better off just getting the entire gauge cluster. If you do a search on the board for gauge swaps they is bound to be a step by step. It shouldnt take too long at all. You have to remove dash pad and remove the bezel from around the cluster. Unplug the cluster from all the connecters and then reverse steps with new cluster
maroe624
Apr 16, 2017 08:29 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
