Strange whining noise
Old Jul 23, 2003 | 11:55 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I have this strange whining noise in my 86 IROC (5.0 TPI, 700r4, 3.23 posi, rear disc). Starts off low, then gets louder and higher pitch as I go faster. If I rev the car in neutral, it doesn't do it.
Ideas?
Old Jul 24, 2003 | 06:01 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Anyone?
Old Jul 24, 2003 | 06:40 AM
gmsmallblockguy's Avatar
tranny pump?
Old Jul 24, 2003 | 06:45 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
need a little more info... maybe the rear? does the noise go away if your rolling and u put it in neutral?
Old Jul 24, 2003 | 06:57 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I agree with 89RS.
Old Jul 24, 2003 | 11:27 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Noise is completely gone in neutral.
Not sure if this is relavent, but my friends and I suspect a previous owner installed a mild shift kit.
Old Jul 24, 2003 | 08:45 PM
Trickie's Avatar
i had the same problem and it was an exhaust leak where 2 pipes connected and it was causing somewhat of a whistling effect
Old Jul 25, 2003 | 06:01 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Nah I don't think it's exhaust because the noise is gone when I'm in neutral. But it does fluctuate with engine rpm's.
Old Jul 25, 2003 | 06:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
If it doesn't start at one rpm and end at another then you can probably rule your ds out. Might want to look at your diff.
Old Jul 25, 2003 | 08:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is it coming from the rear? My rear whined like that, and I found it was pinion bearing. Not a hard job - took me 2 hrs. alone in the yard.
Old Jul 28, 2003 | 06:02 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I suppose it might be the rear.
Old Jul 28, 2003 | 06:47 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Last strange whining noise I heard was from my ex-wife...
Old Sep 23, 2003 | 02:06 PM
cmexlr8's Avatar
Car: 1965 Chevelle SS
Hey Mikes86SC - did you ever figure this problem out? My 88 IROC 700r4 does the exact same thing. It whines when in gear, but not in Park or nuetral and the pitch of the whine changes with engine rpm.
Another weird thing is the shifter will not allow the tranny to go into park. It makes me think that the cable is loose because I have to shift past the gear I want and then bring the shifter back until it locks on the gear I want.
I am more concerned about the whine though.
Old Sep 23, 2003 | 02:07 PM
cmexlr8's Avatar
my bad, I didn't realize this was in the engine forum. I will post this in the tranny section.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
