305 4-bolt???
Car: 1987 Z28 Convertible
Transmission: 5-speed
305 4-bolt???
Ever seen a 305 4-bolt block? You have now!!! This includes two-bolt ARP studs on the inner and splayed 12-point ARP bolts on the outer..
This is the foundation for good things to come, including all 4340 internals, and lots more boost, most likely in the 20+ range. Soon my friends, I should easily be running 11's with my fully optioned (including A/C), emissions-legal, daily-driven 305....
One doesn't exist from the factory. This is a four-bolt conversion.
Willie
Willie
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Willie
One doesn't exist from the factory. This is a four-bolt conversion using splayed bolts AND two-bolt studs. This is as strong as you can build main caps.
Willie
Willie
ahhh... that explains why i never heard of it.
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Actually there were 305 4-bolts around, but not automotive applications, look at marine applications. Unfortunatly they are not splayed 4-bolts, but the normal factory type straight 4-bolt.
I believe these blocks also made it in to the "Iraqi Taxis" that were shipped over seas in the '70s.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i was actually thinkin of that last month when ever my motor blows or if i just wanna get it rebuilt someday i think ill have that done.
also does anyone know, i was lookin under my car these past few days and i noticed it said 551 where it has those numbers on Willie's block. what does the 551 mean? i know i have a 305 but do those tell anything special about the block?
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
well i guess i'lll be the first to ask how much would something like that cost me now i might stay with my lil 305.........TBI!!!!!!!200 hp shot of nos here i come and 9inch ford.:hail: :hail: :hail:
Great job Willie.
Can you send me some details?
Cost and who did the work.
Would like to know once it is time to rebuild mine.
I would rather have someone do it that has some past experience.
Otherwise, mine is still running strong!
Keep us posted.
Keep us posted.
I was telling a friend of mine about your project.
He said that the 305 can be modified for a 4 bolt application with machine work to the block.
Do you have any particular advise to add concerning the conversion?
Thanks!
Thanks!
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Awesome! I didn't know if that could be done.
So Willie, are you using the same procharger you have now, just changing pullies for the boost? As I recall, you bought a much-upgraded supercharger originally so you could do this.
Good luck, and keep us posted on the results! I want to see a sub 12 second 305!
I guess that would depend on what else you're having done as long as the block is disassembled. I'm going all out so it's going to cost a lot.
What specifically do you want to know, everything I'm having done? Man, that's a lot of typing...
I'd have to itemize all my parts and labor, which I haven't done yet. A local machine shop finished the job a couple of days ago.
Would like to know once it is time to rebuild mine. I would rather have someone do it that has some past experience.
If you want to come out here, I'll give you the name. But I have a feeling you'll find someone locally that has as much experience.
Here's one more pic:
OK Now you are just teasing me!!!
You know that you and I are the leading edge on the 305 with you being the master!
I will be adding a new SMC progressive alky injection system with a 15# pulley.
I am looking to you for experience once the stock bottom end blows!
I have your basic set up already. Just need advise on a new engine rebuild. Send me a PM when you get some time.
Good luck with yours!
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Hey Willie..
Did you get the part numbers on the 12 point bolts for the splayed caps? appricieto..
I'm slowly getting parts together for a 302..
either a 283 steel crank or 302 SJ crank with spacers or if I can find one at a decent $$ a 302 LJ crank, which I'll turn the rods down to 2.00 and destroke it .050".
using TRW 2441's, and 6" H-beam rods. (nascar stuff) lol
thanks, BW
thanks, BW
Missed a few:
....He said that the 305 can be modified for a 4 bolt application with machine work to the block.
Any 2-bolt Chevy small block can be modified.
Have a pro do it!!
I've had a D1SC for almost three years now. My plan was to keep it and use the cog drive on it, not knowing how much boost it would create. Update: It appears that today (08-09-03), I have sold the D1SC. If the deal goes, I'll be getting an F1.
Thanks and I will. Although I don't like to guestimate what times I'll run, I can almost guarantee that it will be 11's. That is my goal and once I achieve it, my car will be considered "project completed".
Did I wet your whistle?
Not exactly. I had to learn from someone too!
So I've read.
I am looking to you for experience once the stock bottom end blows! I have your basic set up already.
You did, but I keep changing stuff, so it's not really true any more!
Better idea: When it's time, contact me! I might reply.
Thanks! I'll need it trying to go where no 305 has gone before (lots of boost, that is).
I did ask the machine shop owner. All he told me was they are 12-point, grade 8 bolts (I forgot the size and length though). I can ask again. The caps are made by CV Products. Much nicer than Milodon's. We had them side-by-side and it was no comparison.
I envy you. I love those wide bore, short stroke engines -- can rev them to the moon!!
Noticed you are running a gear drive... any problems with it setting the knock sensor nutz?
I've had the Pete Jackson "quiet" gear drive since 1999. No problems whatsoever. I will be installing them on my convertible's 305 when the time comes.
Hope I didn't miss anyone this time....
Willie
Have a pro do it!!
So I've read.
Willie
Thanks for the nice long post!!
Yes much drool going on here!!
So you are going with the F1!
You dog!
There will be a lot of pissed 383 owners on the board really soon.
Hopefully I won't need to contact you about a rebuild for some time. Watch the knock carefully and get the alky flowing.
Too hot here to work on the project. Roast you alive!
Will get on it in October, if I can hold out.
You dog! There will be a lot of pissed 383 owners on the board really soon.
Robert,
The pistons are made by JE and they are -12cc dish. The chamfer on the edge of the cylinder wall is worth -2cc. My AFR 190's are 55cc. The Cometic head gaskets I'm using are 4.165" diameter and 0.078" compressed thickness. This yields a C.R. of 8.5 to 1. It was 9.2 to 1.
Willie
Willie
Car: 1991 Z28
Willie that is sweet!!.....Hell...I have a 350 and I envy being able to have an 11sec daily driver...with all options still on it. You have to tell me what kind of supercharger I could start out with on my L98......
Personally, I'd start out with an ATI D1SC with twin intercoolers.
Willie
Willie
Car: 1991 Z28
Ok Willie...here come the questions...lol First, price?? Im getting ready to have my block rebuilt..and was putting the 4bolt adapters in it anway....do I need a forged crank for a relative low boost? Id like to have a decent 13sec car......What about the tranny? rear end etc?? Im pretty good on the computer end....but if you could get me started on what all Id need to get going...I would appreciate it. Thanks in advance......
Go to: http://www.tenperf.com/
Dave is the only dealer with the twin intercooler D-1SC set up for 3rd gen F Bodies. You are looking at about $3600 for the set up. More or less.
Willie will have to direct you to other expenditures.
Manual or auto tranny?
I am looking at a TKO 5 speed tranny once the T5 blows.
Still good though with a 12's TA running 10 lbs boost on a D-1SC.
15# to come by Fall of this year.
Sean (aka mypontiac) answered already.
No. The stock bottom end can easily support 450 - 500 hp. The weak link are the pistons. Buy a good set of forged castings. And with any power adder, you'll need an aftermarket ignition. Although the stock HEI is an excellent design, it craps out quickly on the high end.
It's not that difficult to have a 13-second 350 without a power adder. If this is your goal, do it with bolt-ons, heads and a cam. The tranny and rear end should be okay, but it's also dependent on how you drive.
Willie
Willie
Car: 1991 Z28
How much power realistically is possible with the base supercharger? I read on ATI's site that there is a 60-85% gain??? Just wondered how true that is. What kind of power could I expect by simply putting the charger/intercoolers on?? I know Id probably end up changing the cam, bigger TB, runners etc.....I start out simple with every car then it turns into a big money pit...lol thats NOT street legal. Thats why Im so interested in the supercharger.....because they are just starting the emissions junk around here....and Id hate to build another car like I had before(high 11sec 383, big cam etc) and not be able to drive it on the street because of emissions. Ive actually made a list of what Id like to do to my car now....tell me what ya think.
Stock block bored .030
4 bolt main conversion....
ATI procharger....
JE or SRP forged pistons
custom COMP cam....
Ported Plenum...
Some type of big tube runner(SLP, edelbrock, etc)
Alum heads(Corvette L98 or something else cheap..lol)
52mm TB
Hedmann dual cat headers
custom dual exhaust(similiar to Willie's) or Mufflex 3.5in catback
Thats about all I have right now. Im guessing alum heads would allow for more timing...just like in N/A cases right?? Could I use the stock heads if I ported the **** out of them...until money would allow for say....AFR's?? I also emailed CompCams about a custom grind for the blower...they said they have several to choose from for a blown TPI. What kind of piston should I go with??? I know the C/R needs to be relatively low, correct? Then again, I might as well go ahead and get the heads I want to use with the blower, so I can choose the right piston.....Im not looking for a big 700hp street machine....just something similar to Willie's numbers(old numbers). Id love to be able to have the numbers of my old car(11.86) AND be able to drive it everyday.........
ATI procharger....
custom COMP cam....
Ported Plenum...
52mm TB
Ahh Willie.. you did it again... man alive your car is gunna be sweet(like it sucked before!). I would like to see a good race between you and a bolt on 03 cobra... that would be sick.
and off topic, Willie(or anyone), have you heard the new kenny bell SC on the cobra?... its sick... 500+hp to the ground...errr i hate ford...
KYL98,
I had some exhaust, valve train and intake mods done to my stock 305. So say I went from 220 FWHP to 260 FWHP.
After the addition of the D-1SC I had the car dynoed and got 345 RWHP which is about 390 FWHP.
So I got a 50% increase in HP.
This was on the stock HEI and after driving for 1 1/2 hrs to the shop!
Car: 1991 Z28
So on my L98, I could expect more? The engine comes out of the car this weekend coming up.....so Im going to have in checked out..new bearings, etc. and have the 4bolt caps put in it....if everything is ok....Im planning on putting new pistons and rods in it, as well as pushrods. When I choose a cam I will get the stock dia springs and new lifters to use on my stock heads Im having ported as we speak. The guy is pretty sure he can get the same flow numbers as the alum L98 heads, maybe a little better.....but do I need alum heads? will it help with the detonation factor of the blower???? I cant wait to get this thing started..hehe
Car: 2000 Trans Am
Willie, Im curious about those pistons. I did a little research and JE makes an "APBA spec" piston for 305's. Im assuming that is what you have. Is that the only good forged lightweight piston you could find for your project or what?
Car: 84 SVO
Transmission: WCT5
Yep, I'm using boat pistons!!! I could only come up with two alternatives:
1) TRW forged in a 60 over (my block was currently at 20 over, so I didn't want to use these. Found them on Summit's shelf. 30 over TRW's (or any other bore size) were not to be found anywhere!
2) JE could custom build a set. However in talking with their rep, he said these spec boat pistons would work very well in a blown application.
Yes, I had thoughts of going to a 350 but with all the machining that had already been done to my 305, that was out of the question. So now the only question I have is, does the APBA run 305's????
Willie
Willie
Car: 2000 Trans Am
Hell, APBA sanctions all kinds of different class racing. They probably have some small piston powered boat class. Who knows.
Good luck with em! Do they come with lowered ringlands or anything like that to help in the case of detonation?
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Car: 84 SVO
Transmission: WCT5
Willie
Willie
Car: 1992 B4C 1LE
I was trying to figure out wher I had heard the "APBA" on the top of your pistons before. They are the "NHRA" of powerboats...
i was just curious.. why a 305? im not flaming the idea, i say to each his own, as long as its fast i like it, just curious why you chose to keep the 305 when many people consider the worst small block chevy ever made, again im not flaming the idea...
As far as choosing engines or whatever, you should choose what works best for what you're going to do. I was amused when I noticed that half of the chevy engines built for the engine master's challenge were based on 307 blocks, probably the one SBC that (undeservedly) gets even less respect then the 305...
Car: 1992 B4C 1LE
I went with less cubes. Taking a 400 block and stroking it way down (327,307 stroke 3.25"). I think less can be more sometimes maybe.
There are times that sorter stroke/bigger bore are a good idea (mostly if you _need_ it to rev and have to do it relatively cheaply), mostly in a light car that needs significantly more hp then torque (either a light road race chassis that just will not hook up more torque, when you do not have a tranny/axle available that can handle more torque or if you need higher speeds and gearing is not available to do it without the RPM). Otherwise it's hard to justify bores over 4" on most modern configurations.
Car: 1989 Iroc Z L98
There's a lot of stupid people out there. If you want an NA DRAG engine then you go with whatever gets you the most cubes for the $ spent. Otherwise, if street time, boost, gas mileage, emissions, dozens of other things… are factors then there are lots of reasons to consider smaller bores (and at times there are still reasons to go with larger ones).
why's this? i have heard (from you) the theories about a smaller bore helping to control the combustion and therefore helping to reduce detonation, is this the only reason you say this? i think i personally would take all the bore i can get, and go with the right stroke thats for the number of cubes i want... i agree that you dont need huge cubes for lots of street power and i'd like to build a motor like b4ctom1
Take a look at what gm has done in redesigning the SBC into the LS*, or the ford mod motors or even the little honda's and other 4 bangers (which require RPM to make hp, and they still have much smaller bore/stroke ratios).
Originally posted by unknown_host
I noticed that trend too, although I think a lot of the driving force behind the decision to build off the 307 is solely for bragging rights- "i won the engine masters challenge with a lame 307" sounds like you have "more know how" than if you were to win the challenge with a $2000 aftermarket block.
NICE 305.............
But thank's just the same i'll stick with my 406TBI.
540HP & 620TQ@FLYWHEEL......
I can't wait to see what it make's at the wheel's but them 3.73's and 295/50R16 Drag radail's should Hold it good......
