Newbe questions about my new 90!RS
First off this car was contrevted from 90 tbi to an90 iroc tuned port.
Can the stock fuel computer messure boost and can I addjust it?
Second is there a knock sensor output that I can datalog?
Thank you,
Shame
Thank you,
Shame
Car: 1990 Camaro RS
no the stock computer only reads a 1bar MAP. so it can't read boost.
yes using craig moates software, or any of the other dataloggin programs, it will give you knock counts.
Car: 04 GTO
Transmission: M12 T56
To expand on Dewey's answer. No, the stock computer ('730 for a 90 SD TPI) set-up as stock cannot measure boost. With a few changes though you can run it as a '749 with a 2 bar MAP which can measure boost (which is what GM used on the turbo sunbird and Sy/Ty)
