RCA cable splitter?
Old Jan 7, 2004 | 11:28 PM
napalmdemos's Avatar
Car: 91 Firebird
RCA cable splitter?
Decided to step up to a 4 channel amp, which has 4 inputs but only 2 come off the back of the head unit. The amp needs to be ran in stereo to be 2 ohm stable.
What type of splitter should I use? Is there a certain name its called? Any suggestions would be helpful.
Old Jan 7, 2004 | 11:40 PM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
It's called a Y adapter ..........1 male 2 female. You gonna run 4 speakers off the amp? If you are the output off the head unit is for the rear only. So you won't be able to fade the output of the amp.
Old Jan 7, 2004 | 11:47 PM
Car: 91 Firebird
I think I am going to bridge it. I was thinking 1 female into 2 male, one for right and left channel.
Will this effect (weaken) the signal coming out of the rca cable by splitting them?
Old Jan 7, 2004 | 11:51 PM
No, it wont weaken the signal.
Old Jan 7, 2004 | 11:57 PM
Car: 91 Firebird
What are the inter connect cables that I see mentioned alot ?
Old Jan 8, 2004 | 12:06 AM
The only time seen referance to that is when I hooked up my sony head to my sony 10 pack changer for the controls.
Old Jan 8, 2004 | 07:28 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
if u need spliters radio shack deff. has em
Nate
Old Jan 10, 2004 | 03:12 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yep just make sure you double cheack the ends everyone sells the 2female 1 male onces too and because they are need in less aplications theres always some of those left and none of the ones you need left. I think walmart sells them too (in the tv section),,,,,dont think they are the gold plated ones tho..if it matters to yah.
Old Jan 10, 2004 | 05:23 PM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
These are the radioshack plugs i bought. Im doing the same thing u are trying to do. they are 4 bucks each btw
Old Jan 11, 2004 | 11:16 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
nible t
woudlnt you wnat to set up your cables different...
it seems the wat that you have them that the front speakers would be mono and then the rear speakers would be the opposite mono. i am trying to say that the way that you have it set up now seems like that you would have all your right speaker sound coming out your front's while you have the left signals coming out the rear speakers
in order to get the stereo effect you would want to have the spliter coming off t he cables and then one of the leads from each channel going into the front and rears. unless you are looking for the effecty of trying to fade, it but you would be fading left to right, but in your case since you set it up in the amp you would be able to do front to rear ?? is that what you were going for ??
i drew up a quick picture, what you have is the frist one, woudlnt you want to have the second one for the right stereo effect and sound coming out of your speakers. i think that this will give you a stereo sound out of all your speakers, instead of 2 different mono's out of your speakes
Old Jan 11, 2004 | 09:02 PM
Car: '81 Trans Am
Engine: 6.6L
i was thinking the same thing...... white91formula is totaly right,,,,try playing with your balance on your deck instead of going side to side(r to l) youll get a front to rear fading.
And your sound would be flat, kind of. Theres alittle sterio but your not utilizing it to its full potential...hook it up like hes got it drawn and youll get your proper sterio sound.
Old Jan 12, 2004 | 08:03 PM
Car: 91 Firebird
How does it sound?
As for the mono thing as long as your running four subs or two bridged I wouldnt think it would matter.
I plan on running my two Audiobahn's bridged but in order to do so it has to be in stereoto be 2 ohm stable, so how would that work with splitting the left and right into left and right agian?
Wouldnt that be crossing signals?
When a amp is bridged doesnt the sound come out in mono?
Old Feb 2, 2004 | 10:57 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
Originally posted by napalmdemos
How does it sound?
yes you bridge down to one channel only, so it would be mono
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
