will a world class t-5 be able to withstand 320 hp?
Old Mar 31, 2004 | 06:59 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
a friend of mine on this site has a World Class t-5, that i am buying . will it be able to withstand 320 hp? thats wut im estimating that will be coming out of my engine.
Old Mar 31, 2004 | 07:21 PM
StealthElephant's Avatar
Car: 87' Iroc
350ft lbs+ will eventually destroy it. It'll last a while tho if you don't abuse it....
Old Mar 31, 2004 | 07:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It should be fine provided to don't intriduce it to lots of clutch drops and or slicks. Traction will eventually kill the T5, not power.
Old Mar 31, 2004 | 08:32 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
torque and traction is the main killer
Old Mar 31, 2004 | 08:44 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I have a NON W/C T5 and have had alot more HP than that to it since 86 with no problems...... the key is what shifty said
Old Mar 31, 2004 | 09:55 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
ok .....thanks guys.....shifty i love ur car:hail: :hail: :hail: sorry for being stupid but just to get it straight......clutch drops meaning- revving and dropping the clutch so the tires BURN.....is that it?
Old Mar 31, 2004 | 10:06 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thx for the kind words and you have the clutch drop idea down pat. They are really hard on the ol' T5
Old Apr 1, 2004 | 10:51 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
see my sig, 330 RWHP and the WC T-5 is fine so far, PM me after this weekend to see how it does with drag radials, pray for me too that it doesn't break.
Old Apr 1, 2004 | 01:08 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
ill pray.......good luck, i think im gonan go with the t-5 then. ill just have to baby it :lala:
Old Apr 2, 2004 | 02:27 PM
johnjm22's Avatar
Car: 91 Camaro RS
Transmission: WC T-5
What is the difference between a regular t-5 and a WC T-5?
Old Apr 2, 2004 | 04:57 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
check sig.
Old Apr 8, 2004 | 07:03 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
a WC is a world class and is supposed to be stronger than the regualar ol' t-5
Old Apr 8, 2004 | 09:28 PM
johnjm22's Avatar
Car: 91 Camaro RS
Okay, I know that, but why is it stronger?
Old Apr 11, 2004 | 11:57 PM
IROCFAST's Avatar
I agree TQ and HP with traction will eventually kill the T-5, my WC lasted over 18mos in my car with drag radials, granted, it did not hook. Another thing that is very hard on the T-5 is the fact that it does not like RPM, anything over 6k is living on borrowed time, the whole thirdgear cluster is just hanging out there all by itself, on it's own shaft and the syncro cannot keep up. That is what eventually killed mine (shifting at 6600). I was amazed it lasted as long as it did.
Old Apr 12, 2004 | 12:14 AM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
it seems like the only thing that ive found that go bad on manuals are the 3rd gear synchros........:werd:
PurelyPMD
May 5, 2016 04:57 PM
gt4373
Oct 8, 2015 10:37 AM
Damon
Sep 26, 2015 04:29 PM
scottmoyer
Sep 7, 2015 07:06 PM
jtwoods4
Sep 3, 2015 05:39 PM
