Power Steering brace with headers
Old Jul 5, 2004 | 08:22 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
The old power steering brace mounted off an exhaust manifold stud that was raised. I have headers with header bolts, and no where to mount this to. I want to get rid of that design and get a new way to mount the power steering. I want to re-use my old power steering pump, but put a different mounting bracket on it. Does anyone make these, or can I grab one from a junkyard off a different type of SBC? Thanks L98 if it matters.
Ryan
Old Jul 5, 2004 | 10:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Attached Thumbnails Power Steering brace with headers-front-upper-side-view.jpg
Old Jul 6, 2004 | 04:17 PM
where do I get one of those? That spacer thing, and the stud bolt to go with it.
Old Jul 6, 2004 | 04:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The stud is stock.
Make the spacer out of a piece of galvanized 3/8" water pipe.... a "pipe nipple" from Home Depot would be perfect. Cut it to the length such that its length plus the header gasket plus the header, equals the thickness of the stock exhaust manifold.
It's pretty senseless to go against the flow and re-invent the wheel, when it's that easy to just use what's already there.
Old Jul 6, 2004 | 04:47 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
I did the same as RB, my spacer is probably the same size but I can't be sure because I was lucky enough to find it in my toolbox and it fit. Now that I have determined the pump is in the correct position I will be removing the unsightly washers and making something a little more permanent.
Si
Old Jan 23, 2005 | 10:45 AM
87camaro kid's Avatar
Car: 1987 Z28
where did the air conditioning pump go? can u just take the pump off?
Old Jan 23, 2005 | 11:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On mine, it went back where it belongs. On the brackets in the pic.
Take it off? I suppose I could have; but I live in a permanent building. Why would I want to just hack up my car that way?
Old Jan 23, 2005 | 01:07 PM
rjmcgee's Avatar
This works good.
Old Jan 23, 2005 | 02:21 PM
Car: 1987 Z28
rjmcgee did u jsut take the AC off and not have to have an idler pully cause it looks like with out the belt the goes around the ac pully everything would still get turned
Old Feb 7, 2005 | 06:07 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
how did you make that power steering bracket. Did you cut the large AC one and bolt it to the support that mounts to the front of the heads??
Also, are those bolts in the front of the heads needed, (like do they go all the way through, or can they be left out?)
Old Aug 4, 2005 | 02:38 PM
bigals87z28's Avatar
Car: Check The Sig
I guess this would be the closest to what I need.
Now, I have TPI, and I dont see that bracket you guys are bolting up to the first header bolt. Ive looked through all the boxes and bags and I have no braket like that. Anyone with TPI can lend an eye on this? I have another thread going, but some here have a little bit better picture of the PS pump.
rjmcgee, where did you get that braket that goes from the PS braket to the other braket bolting to the head?
Old Aug 4, 2005 | 03:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Posted by a member on the Engine Swap forum. The only thing it doesn't show is the modification required to the top AC compressor bracket - cutting off the back leg that goes to the back bolt of the #1 primary.
Attached Thumbnails Power Steering brace with headers-z28_bracketstgo_080305.jpg
Old Aug 4, 2005 | 04:00 PM
Car: Check The Sig
Ok, that looooooong bracket that comes up from the bottom, near the oil pan...dont have one of theos.
Old Aug 4, 2005 | 11:07 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Power Steering brace with headers
Ryan
Im surprised they didnt include the spacer with the headers. After two header swaps I have at least three of those things in the HW drawer for some reason.
Old Aug 8, 2005 | 08:15 AM
I bought the headers off e-bay from a junkyard. They took them off a '92 camaro. The water pipe spacer works great though. Add a little black high-temp spray paint and it doesn't look too bad either.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
