South Central Region Board for the states of Texas, Oklahoma, and Louisana.
went to HRP last night
Old Apr 18, 2005 | 12:50 AM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
took my 87 Z last night to the HRP 1/4 track..car is stock 305 TPI````````new times w/headers
R/T 1.01```````.92
60" 2.21``````2.19
330 6.40``````6.23
1/8 9.84``````9.57
MPH 71.81````73.93
1000 12.85````12.48
1/4 15.45`````14.97
MPH 86.20`````90.50
93 Z stock lt1 1/8 mile times at HMP
R/T 1.33
60" 2.33
330 6.33
1/8 9.67
MPH 72.76
i think i had too much weight on the 87 z full tank, subs, tool box.....and after a beer or 2 new poly trans mount worrked great. i wanna know if there's room for improvement ...
6-18-05 went to track with rest of H-town TGO members and pulled off some improved times ...Im glad everybody helped me out when i ran into some problems
Old Apr 18, 2005 | 04:07 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Transmission: TH-350
Axle/Gears: 3:73
I think "the beer or 2 " caused your reaction times to be poor. The extra weight probably helped the car hook better, but slowed it because you had to drag it down the track. Keep workin' on it!
Old Apr 19, 2005 | 11:42 AM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Something isnt right with your 93, that car should be in the high 8's. if you cut a 2.0 60 with your 305, it would probably take your LT1 in the 1/8.
Old Apr 19, 2005 | 04:55 PM
rudyt5000's Avatar
my transmission mount is out on the 93 Z....but i decided to put a poly mount on da 87 ....i dont really like the 93 too much so it'll get cheap rubber mount
Old Apr 19, 2005 | 09:18 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Were you manual shifting or letting the car shift itself?
With less weight and a few "free mods" you should pick up about 2-3 tenths.
Old Apr 19, 2005 | 09:26 PM
rudyt5000's Avatar
yeah i let it shift itself...and it was a spur of da moment when we went to the track...i didnt even think about how much gas i had but i got gas for 1.98 so i filled up and they were about to close da track already so i was kinda in a rush..i will be back later prepared and hopefully see some improvement.. tach is way off bout 2,000 rpm so i dont want to shift it manually and mess up something
Old Apr 20, 2005 | 09:44 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I've got a 3 1/2" Sport Comp tach-(works great) for sale!
Old May 24, 2005 | 10:27 AM
rudyt5000's Avatar
well i just bought some edelbrock shorty headers and y-pipe for $70 ...im cleaning them up right now and hopefully i have them on before summer meet. I was wondering if could re-use the same manifold bolts ? i'll post some pics of them today
Old May 24, 2005 | 11:32 AM
rudyt5000's Avatar
big difference
shiny ...hopefully i see some improvement on my 1/4 times from last time i went ....
Old May 24, 2005 | 12:52 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
What a steal!
Not sure about the bolts are the old ones go through a flange the same thickness as the headers. U can get some header at almost anywhere Oreolly's--Competition sales--Summitt--Jegs--go to summitt and search for header bolts and they may show the length x diameter--etc!
Old May 27, 2005 | 06:13 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Hey Rudy,
Still got that 3 1/2 Auto Meter Sport Comp Tach--want it?
Old Jun 2, 2005 | 11:20 PM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Thats odd my 93 Trans Am when it was stock ran 9.1@78 in the 1/8, that was on a 2.25 sixty foot. At HMP I ran a 8.5@80 on a 1.86, still basically stock, just now with 17s, a converter, cat back and a cold air.
Old Jun 2, 2005 | 11:46 PM
rudyt5000's Avatar
well i guess it might also have been cause it was my first time at the track i also use 87 octane ...and i really think that broken tranny mount really killed everything ...also budweiser too
Old Jun 19, 2005 | 11:00 AM
rudyt5000's Avatar
new times
well my new best time with headers now on the 305 tpi
R/T .921
60" 2.19
330 6.23
1/8 9.57
mph 73.93
1000 12.48
1/4 14.97
mph 90.50
what a difference those headers made...im guessing what a cam would do
Old Jun 20, 2005 | 05:49 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Re: new times
R/T .921
60" 2.19
330 6.23
1/8 9.57
mph 73.93
1000 12.48
1/4 14.97
mph 90.50
As long as U do not "overpower" the heads! The heads can only flow so much air. Even if U have them "done"--if U try to flow through them than they can take, U will actually LOSE HP!. It causes turbulance when that happens and U actually flow less if U force too much in them. The cam has to be somewhat matched to the heads--do a search or post questions on the TPI board about which cam for your 305 with the mods u have or plan on in the near future.
Old Jun 20, 2005 | 05:55 PM
rudyt5000's Avatar
thanks Zap for the advice...i will hold out on the cam idea ....first im gonna try some better gearing from blackwidow 3.43 so if that will improve my time i'll work on porting my intake and simple stuff like that before i dig into the motor
Old Jun 20, 2005 | 05:57 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Have U put the "airfoil" on the front of the throttle body yet?
Remove screens from the MAF yet?
Old Jun 20, 2005 | 06:41 PM
rudyt5000's Avatar
airfoil not yet ...but i have removed the MAF screens ....tb bypass, i'll try the airfoil some time later and maybe some roller rockers...i do plan on getting a different motor to replace it once this 305 goes ....but this motor takes some abuse and doesnt give up ...
gixxer92
Apr 12, 2022 12:09 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Derrick86
Oct 1, 2015 05:12 AM
gord327
Sep 29, 2015 10:18 PM
