Who rebuilds a TPI throttle body?
Old Apr 26, 2005 | 12:08 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
The bushings are shot in my throttle body causing the blades to hang open. So instead of spending an astronomical amount on a new one, I'd like to have this one fixed. Its already been bored out to 52mm, so thats a plus as well. I swapped my stocker back on this week and was amazed at the difference in how smooth the car drove now that the TB pivots normally.
I've done some searching on here and google with no real luck.
thanks
Old Apr 26, 2005 | 09:44 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
horsepowerguy@sbcglobal.net
This guy in Texas took my stocker and rebuilt it along with a bore to 52mm and threw in an air foil for $200 or so. Check out if he would just do the rebuild part...
Old Apr 26, 2005 | 12:38 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
Any true carb rebuild shop should be able to bush your tb shaft and reset the blades in the bores properly
later
Jeremy
Old Apr 27, 2005 | 08:22 AM
LedHeadRed's Avatar
Car: 1990 Corvette
Engine: 355cid
Transmission: ZF-6 speed
Axle/Gears: stock 3.33
I would recommend contacting Dave Koldos, he's well respected due to his flawless work and reputation. He's in Elgin, IL. Email him at: dkoldos@ameritech.net
I believe he charges $175 for a complete rebuild which will last for a very long time.
Old Apr 27, 2005 | 09:18 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I was reading about this guy's work on his FAQ page yesterday, weird. I started to contemplate sending my throttle body over to him for a rebuild, but didn't know much about him... or his work.
Glad to hear that somebody had a good experience with him. Thanks.
Old Apr 27, 2005 | 09:34 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What could be so hard about rebuilding a throttle body that requires a $175-200 charge? Does that include polishing it too?
Old Apr 27, 2005 | 09:40 AM
Originally posted by Tibo.What could be so hard about rebuilding a throttle body that requires a $175-200 charge? Does that include polishing it too?
FAQ Page
Old May 1, 2005 | 07:11 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
That FAQ says that the (EGR circuit) needs to be moved on the TPI? Why's this necessary?
Old May 1, 2005 | 08:23 AM
Originally posted by Goumba T.That FAQ says that the (EGR circuit) needs to be moved on the TPI? Why's this necessary?
Hey Goumba, as they say on KTU, "how youuu, doin"?
Man, I haven't been to Howard Beach in a looong time! Is 'New Park Pizza' over on Crossbay still there?
What he wrote is correct. He's referring to the EGR's passageway in the throttle body. I too, initially thought he was referring to something electrical when using the word 'circuit' (that is, if this is the same impression that you received from it).
Old May 1, 2005 | 08:42 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Heh, I haven't listened to KTU in a long time. When Joe Causi went to 102.7, I went too. And yes, New Park is still there.
At first I was thinking electrical, but then I realised that none of those electrical connectors are EGR, so he was referring to the passage. However, I was wondering why relocating that passage was even necessary. Does it interfere with the rebuild, or does he feel its better off somewhere else?
Old May 1, 2005 | 08:51 AM
Originally posted by Goumba T.Heh, I haven't listened to KTU in a long time. When Joe Causi went to 102.7, I went too. And yes, New Park is still there.
I know. I've been a fan of 103.5 ever since they were HOT 103 (Scotty Blockwell days), mid to late 80's... then they went to 97.1, then again back to 103.5. Now I just listen to XFM (constant early/late freestyle & House).
Originally posted by Goumba T.However, I was wondering why relocating that passage was even necessary. Does it interfere with the rebuild, or does he feel its better off somewhere else?
When he bores out the throttle body, the cutting makes it's way into the EGR vacuum passage... which he then must fill. It's much easier for him to simply relocate the EGR line, than it would be to literally reconstruct it, then somehow try and adapt it to the new bore size.
Old May 1, 2005 | 10:37 AM
formularpm's Avatar
Car: '89 Formula
Axle/Gears: 9 bolt
A friend of mine bores and rebuilds them with roller bearings instead of bushings. You can PM me and Ill give you his email if youre interested. Not sure about price, but without the labor for boring and cutting new blades, I would imagine it would be relatively cheap.
Old May 4, 2005 | 04:20 PM
chickenhawk's Avatar
Car: 86 Monte SS
Engine: LS2
Transmission: 4L65E
David Koldos has my vote!! He did an awesome job on mine including throttle plate bearings and the above metioned EGR provision.
I gave him my air foil prior to boring it out so that the new bore size ( 52MM ) would blend nicely with it installed.
Super nice guy to work with too!!!
See my attached pics.
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
