Timeslip Comparison
Car: 1986 Camaro
Engine: zz4 350 w/mods
Transmission: 700-R4 W/Shift kit
Timeslip Comparison
I just ran a 7.91 at my local track (1/8 mile) at 90mph with a 1.8 60ft on street tires. Does anyone have an idea of what this equals in the 1/4?
Car: 1986 Camaro
Originally posted by vejatabul
12.33 and at least 112mph. improve your 60' please.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1/8 x 1.56 is only a close estimate but it's the one I use also. Each car is a little different but that will give you a number close enough as a guess. Some cars will run slightly faster, some slower. It depends on weather conditions and how well the car runs at top end.
Car: 87 IROC L98
I get the same answer with both formulas.
My 10.546 run comes out to 10.56 with both formulas.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
The 1/8 mile time * 1.56 is a good one to use.
However, if you are like me and can't floor the car until about 40mph, it means zero. Or if you use nitrous in a higher gear (as opposed to off the line).
dbrochard
Sep 19, 2015 08:13 PM
