The Cruise Control Will Function With Motor Swap and Deleted Computer
Old Jul 19, 2005 | 04:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Recently, after much searching on TGO, I concluded that there was no definitive answer to whether the cruise control would function or not if the computer were jerked in a swap. Long story short, at least on my 85 Camaro--and probably all thirdgens with the VSS buffer box on the rear of the cluster--the cruise will work. Quite simply, when the computer is removed, the ground that the computer provided for the VSS is lost. Reground the VSS and the cruise will function as designed. Note the pic: The black/white wire issues from the IP harness under the pass side (my plug won't look like yours as many of the wires were eliminated--just locate the black/white wire).
JamesC
Attached Thumbnails The Cruise Control Will Function With Motor Swap and Deleted Computer-gnd1.jpg
Old Jul 19, 2005 | 04:38 PM
JamesC's Avatar
This plug and its black wire go to the cruise control module, again under the pass side. Join the black/white wire from the IP harness to the black wire from the cruise control module with a length of wire and enjoy. I used a couple feet of 14 gauge, stripped, soldered, and taped. By the way, I chose this method for what I saw as convenience, but the black/white wire could be tied into and grounded elsewhere.
JamesC
Attached Thumbnails The Cruise Control Will Function With Motor Swap and Deleted Computer-gnd2.jpg
Old May 25, 2006 | 04:43 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
thanxs james for the response but i was asking if it would mess anything up to remove cruise. not only does it not work but i dont want it anyway
Old May 22, 2016 | 09:31 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Re: The Cruise Control Will Function With Motor Swap and Deleted Computer
So I'm trying to get my cruise control to work and came across this thread. I can't find those plugs? My Camaro is a 86 so I don't know if they changed plug design but the plugs I found are completely different. One of the plugs has a black wire with a white stripe but the other plug doesn't have a black just a dark brown
Old May 22, 2016 | 10:49 AM
JamesC's Avatar
I'd be surprised if the plugs were different, but, of course, anything is possible. Perhaps, you'll find something in the following link:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old May 22, 2016 | 03:04 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I don't care how old the thread is. James is on this thread and that's who I was asking.
I found it James I appreciate it.
One question the plug that has the black wire with a white stripe does it need to be plugged in for that wire to be grounded?
Old May 22, 2016 | 03:44 PM
JamesC's Avatar
The way I did it, IIRC, was grounding the black/white wire through the cruise control module and its ground. At any rate the black/white wire requires a ground.
EDIT: With the computer gone, the black/white wire isn't grounded, thus the need to reground.
JamesC
Old May 27, 2016 | 06:05 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
That's why I love this place!!
James got it working man! I highly appreciate it! This is the second thing i have fixed this week because of you're post.
Old May 27, 2016 | 06:43 AM
JamesC's Avatar
Originally Posted by fokeyman
Welcome to TGO, where anything is possible.
JamesC
Old Jul 9, 2016 | 12:06 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Axle/Gears: Zexel Torsen 3.73, 28-spline mosers
This is actually might be very relevent to me if I do my 400 swap and go with the DFI controller. Won't need my ECM anymore with it and not sure if I can leave it connected or not.
Old Jul 16, 2016 | 10:19 AM
senior bear's Avatar
this has answerd a question i had about the cruse
Old Jan 24, 2017 | 11:47 PM
Johnathanpx's Avatar
So you can completely remove the ecm with no problem? I have a 91 and it's already swapped and carbed. The computer is just basically sitting their and I wanna clean up the engine bay and wires.
Old Jan 25, 2017 | 11:31 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You would need to install a vss buffer in place of the ecm for cruise control function.
If you have a automatic 700r4 you would need a lockup kit.
https://m.summitracing.com/parts/tci-376600
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
