Burn outs
Old Dec 10, 2005 | 05:55 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Burn outs
How many gears can you TPI guys spin your tires through? Also what Engine,mods, and gears do you have.
Old Dec 11, 2005 | 06:34 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
i can spin em into overdrive
just kidding, 1st and 2nd, 3.73's
Old Dec 11, 2005 | 07:38 PM
Shagwell's Avatar
Car: projects.......
humm...time for traction everyone.... - anyhow, it all depended(not TPI anymore) on how high I wound it while still toeing the brakes you can get clear into OD if you're trying, but WHY? - lca's+relocates, torque arm, 1.66 60fts on 17's... of course, I can still go 1-4 w/ the stick coming out of the bleach box...
Old Dec 12, 2005 | 08:54 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
I say it better if you can't spin because that means that your getting the power to the ground, or maybe you just have a weak engine. Anyway, I've noticed that it depends a lot on the road conditions. With my car, sometimes it will hook up and it won't spin at all. Other time I can spin through 2nd. When I power brake it I've had it spinning in 3rd with the speedo at 100mph and the car was slowly rolling.
Old Dec 12, 2005 | 08:58 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Re: Burn outs
All of them with the linelock engaged
Old Dec 12, 2005 | 10:38 PM
Car: ws6
Engine: ls1
Transmission: m6
I can spin 1st and 2nd. Do you guys think that if I droped in a 5 speed I could chirp third?
Old Dec 13, 2005 | 09:29 AM
vbMike's Avatar
I would think so.
If it was me I would put in a 6 speed T56 instead of the T5. There is a good change that the T5 won't hold up if you are hard on it.
Old Dec 13, 2005 | 09:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Burn outs
an old man once told me there are no stupid questions.
he was wrong.
if you can spin, then you have traction issues.
since the SUSPENSION makes more of a diff then the engine does, im going to go out on a limb and say the guys with the saggyest rear springs and worn rear shocks can spin them the most since their LCAs will lift up and let them spin...
Old Dec 13, 2005 | 11:06 AM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
Re: Re: Burn outs
he was wrong.
Old Dec 13, 2005 | 11:49 AM
Car: ws6
Engine: ls1
Transmission: m6
Originally posted by vbMike
I would think so.
Thats what I was thinking. The T5 cant handle much over 300 lb ft. I still have to work on traction some new radials should do the trick.
Old Dec 13, 2005 | 11:53 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Yah this post is kinda silly, not really sure why I am replying to this but what the heck.
See the sig for mods. I dont really do huge burnouts very often but I can bark the tires in 3rd gear every time. Some guys heard me doin it in an autocross event this summer, needless to say they were wondering why I was in the stock class . I told them my car was stock, it appears stock, but they laughed and didnt believe me.
Old Dec 13, 2005 | 12:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i got adjustable shocks/eibach springs, LCA's and reloc brackets but its not on the lowest setting, and spohn LCA's, hotchis panhard bar
3.27 gears and 2800 stall
in first, if i punch it from a 10-15mph roll it will spin abit then hook up and take off.
if stand on the brake and get it going in first spinning while doing a burnout, and let off the brake and shift into second... it spins thru about half way thru second then dies. my traction is alright
Old Dec 13, 2005 | 05:26 PM
Car: ws6
Engine: ls1
Transmission: m6
[QUOTE]Originally posted by 1MeanZ
[B]Yah this post is kinda silly
Ya it is but what the hell people will get over it
Old Dec 14, 2005 | 10:32 AM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
[QUOTE]Originally posted by 89IrocZ350TPI
[B]
Nothing wrong with burnouts!
I mean, what fun is there in having 345lb-ft with no high rpm pull if you can't do a burnout every once in a while.
Old Dec 14, 2005 | 10:35 AM
vernw's Avatar
Old Dec 14, 2005 | 12:36 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
burn outs are no fun...i like 1.7 60' times!
Old Dec 14, 2005 | 12:53 PM
brutalform's Avatar
First gear, after the water box, with the line lock on!
Old Dec 14, 2005 | 12:55 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
TPI Thirdgens,
The Original Drifters lol
The day I dont giggle like a school girl after leaving a patch will be the day I kill myself :-)
later
Jeremy
Old Dec 14, 2005 | 01:15 PM
vernw's Avatar
Yeeeaaah!!!
Old Dec 14, 2005 | 01:46 PM
Car: ws6
Engine: ls1
Transmission: m6
Thats the best thing about tpi it makes a whole lot of torque. It does lack high end horse power though
Old Dec 14, 2005 | 02:51 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
With the 2.73s, best i've ever done was 3rd gear @ 4200rpms on the line lock.
From a dead stop with no brakes, 1st then shifts 2nd and holds at about 4600rpms and rides it out for quite a ways.. it really depends on the pavement though. sometimes it hooks up
Old Dec 14, 2005 | 05:20 PM
vbMike's Avatar
Yea I've had my car in 3rd with the speedo reading 100mph+ and the car was barely moving. The problem is trying to clean all of the rubber off the car after I'm done. That sh*t is almost impossible to get off.
I guess the trick would be to get 1.7 60' times while doing a burnout. That would be impressive!
Old Dec 14, 2005 | 08:41 PM
Car: 89 Formula
Engine: 5.7 TPI
that would be impressive!
Old Dec 14, 2005 | 08:55 PM
Shagwell's Avatar
1.7 60 fts? you weenies... how 'bout 1.66 on 17 inchers?
- Unless I try to spin, I don't. My car will hook in the rain. - A buddy of mine is on here, can't think of his screen name, but he can vouch for it.(i'll find out if ya'll feel like calling me out) - My best run at the track was 11.7@136. My 60fts are always between 1.66 and 1.70. - I launch over 4500 too...
Old Dec 15, 2005 | 08:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
when the weather goes below 40*, i can easily spin the Nitto DRs on the hwy from a 40-50ish MPH roll...
does that help? LOL
Old Dec 15, 2005 | 01:19 PM
vernw's Avatar
NO! LOL
Old Dec 15, 2005 | 03:46 PM
brutalform's Avatar
does that help? LOL
Aw, heck, I can do that in reverse on ice, with or witout slicks. LOL
Old Dec 15, 2005 | 03:51 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
When the car was stock
Old Dec 15, 2005 | 07:26 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I can spin them to about 25 which is most of first, spin the tires into 2nd for a few and chirp 3rd with the tire pressure at 35 lbs. But I usually run about 25 psi to get good traction if i plan on cruising the town for cars.
Old Dec 15, 2005 | 07:40 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I can go in reverse and neutral drop it into drive and spin it for like a million billion miles! I like to burn out so hard my transmission smokes.
Old Dec 15, 2005 | 08:03 PM
Car: ws6
Engine: ls1
Transmission: m6
Ahahaha
Ya when I burn out I torque my engine so high that the motor mounts give out.
Old Dec 15, 2005 | 08:38 PM
Whats the best way to leave a 'patch?'
Just hold your foot on the brake and mash the go pedal?
Old Dec 15, 2005 | 09:13 PM
Put the nose of the car against a wall and mash it, let it go through all the gears and cruise in 4th rolling the tires off until they burn down to the rims. That'll leave a HUUUGE patch, and if your car breaks while doing it it sucks.
Old Dec 15, 2005 | 09:16 PM
In all honestly on Firestone Firehawk directional street tires my car would probably roll them off till third gear if I broke them loose, I make sure not to do that though by easing into the pedal on the street, they don't spin at all, all hook and go. Burnouts at the track I usually clear first without using the brakes (but don't let it shift, bad for the trans), this usually scares the CRAP out of the guy running the tree when I get sideways in the box.
Old Dec 15, 2005 | 09:18 PM
Shagwell's Avatar
thats the stock, I don't like my rear brakes way. The BEST way is to find the wonders of a line-lock...which leads to "Honey, I know I JUST bought new tires...but I think I might need some new ones..."
Shagwell's Avatar
I shift my stick coming out of the water... 1234... real men don't need no stinkin' clutch pedal...
Old Dec 15, 2005 | 09:33 PM
brutalform's Avatar
How long will it go? Man, my sides hurt from laughing. You guys kill me!!!
Old Dec 15, 2005 | 09:39 PM
One time my friend did a better burn out than me by pouring 2 quarts of 10w30 Valvoline on his tires, but that's cheating!!! Sometimes when you're at the track if you wanna look cool stick your car in reverse at the 8th mile and let em eat people will be like WOOOW HIS CAR IS SO POWERFUL ITS BURNING THE TIRES AT THE HALFWAY DOWN THE TRACK. And remember you're not cool unless you can make your Camaro burn out SO HARD that your front tires pop.
Old Dec 15, 2005 | 10:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i seen those vids LOL very nice
Old Dec 16, 2005 | 12:27 AM
3.8TransAM's Avatar
Heres my favorite retarded burnout moment.
1.54 60 ft spraying out of the hole while spinning the M/T's in a friends juiced 88 GTA.
This occured with a posi we pieced together from my junk parts cause his c-clip let go(wonder why? lol) and we needed it to last exactly one track day :-)
later
Jeremy
Old Dec 16, 2005 | 08:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol at the oil thing...
ive made a couple car vids, and the oil trick works great.. makes more smoke without making it look like bleach was used... it also seems to let the tire last longer.. not as much rubber taken off...
Old Dec 17, 2005 | 07:24 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Put the nose of the car against a wall and mash it...
Old Dec 18, 2005 | 12:49 AM
CrazyHawaiian's Avatar
Car: too many ...
Halarious. I think it depends on the tires. Even the weakest motor would be able to do a burnout with crappy enough tires. For fun I put 195/60/15's on the rear of my IROC and I could spin it all day long. Dosnt matter what mods or gears I have hehe. About the drifting thing, I gotta say burning out is not drifting but its still alot of fun!!
Old Dec 18, 2005 | 05:26 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
burnouts
well guys
i done a 321 ft burnout in the GN @ 20 psi of boost.
of course with 350 RWHP and 440 RWTQ that was fun
i only brake boosted it to 2 psi and let go of her
i done it in front of my friend's house and pissed all of his neighbors off. hell they even called the fire dept for all the smoke lol
and at the track it's capable of 1.80's on street tires too
with the slicks on 1.60-1.64 @ 4-5 psi on the launch
the camaro i dunno have not got to drive it long enuff to do a burn out. i bought it with a blowed head gasket. but i got it running today gonna finish her up tomorrow. so i will see what a 2.73 posi and a nice running 350 will do
Old Dec 18, 2005 | 08:23 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
GN's ARE BAD @SS!
Old Dec 18, 2005 | 09:17 PM
1.50 60' > Smokin 1st, 2nd and 3rd
Burnouts the ******* way:
Block car on cinder blocks
Remove rear wheels
remove caliper
Pinch brake line
Put wheel back on
Tighten lug nuts
Find a strait road
Stall it up
Hit the go-pedal
Old Dec 19, 2005 | 08:19 PM
Shagwell's Avatar
any of you guys ever done a good ole fire burnout? dump about 1/2 gallon of gas on the ground, as you roll though it and go to light up your tires, hav e buddy throw a match into it. rooster tails of flames baby!
disclaimer: I do NOT take responsibility for your actions and/or your stupidity for doing the things that I do...
but it looks COOL!!!!
Old Dec 20, 2005 | 12:12 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
at work we have a little gmc sanoma 5spd 4 banger 2wd and once only once ive gotten it to barley chirp 4th i can get 2nand 3rd all day long. in my T/A i could almost always chirp 2nd w/ a 700r4 stock when it was smewhat cold out. good friend of mine had a 83 crossfire w/ 700r4 and he could chirp 3rd all day long
Old Dec 20, 2005 | 07:52 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
obviously YOU have not done this either.
there is a world of difference between EXPLOSIVE and FLAMMABLE.
Old Dec 20, 2005 | 11:58 AM
8UpAFord's Avatar
Car: 1988 Corvette
Yeah that sounds Like a great Idea if you wanta burn your *** on fire! hahaha you should put a "don't try this at home" in your post.
